Windowlover
- Sep 13, 2009
My set seem OK with digital antena..
I lived in the Pioneer area at Jurong West, and notice only recently there's a significantly signal strength drop.Your area reception is good la
Mine is behind a hill so that’s the issue I suspect
if you have an amdroid phone or tablet, you can install mwatch. dont have to record anymore, all past program can be found on it.I lived in the Pioneer area at Jurong West, and notice only recently there's a significantly signal strength drop.
I have 2 set-top boxes, 1 in my living room (a ukobox STB) for recording those Tamil movies which I love (but which is almost impossible to get from online with good engsub), and 1 draco STB in my bedroom connected to my old non-smart non-digital tv.
Early this month Dec (can't remember exactly which day), my bedroom Draco STB showed a No Signal.... after working for at least a few years with no issue.
Due to previous purchases and subsequently spoilt cheap STB, i have the following antennas,
1) Living room ukobox STB connected to a Funke DSC560, used to be 100% strength and 100% quality... so i seldom check as recordings seem ok but every 10 mins or so, there will be a digital disruption, which I thought is probably due to the STB being a cheapo and and could be due to overheating or resource overloading etc etc... However, after i got the No signal in my bedroom draco STB, my ukobox STB was still working connected to the Funke DSC560 antenna BUT I notice the strength had dropped to 30+% whereas the quality is still at 100% (same location in the living room). Adjusting the antenna's position near the window did not help at all, be it vertically or horizontally, staying at 30+% strength (at most jump to 40+%) for ALL the free sgp channels.
2) My Draco STB was connected to a cheapo antenna (but which can be powered by a USB port). Surprisingly, when I connect my Funke DSC560, my Draco STB is still showing a No Signal , though my ukobox STB works with the Funke DSC560 (but with 30%+ strength only). But my ukobox STB also does not work with the cheapo antenna (in living room and in bedroom).
3) I have a 3rd antenna, the now-mostly-out-of-stock Daiyo EU1702, and guess what, my Draco STB works with the Daiyo EU1702 !! inside my bedroom as per the original arrangement. Strength at 98% and quality at 92%, which is same or similar to what I had in the past when using the cheapo but usb-powered antenna.
4) All other cheapo non-branded antennas, be it standalone and/or USB-powered ones did not work with both my ukobox and draco STBs now when I try connecting them.
Am I right to say that there is definitely a degradation of digital signal in my area? This can be reported on the one service app as suggested by gregory_choo ?
I wish life is that simple.... I know... I even download all the local shows to watch them offline (and some to keep).... But life is always not that simple.... read my 2nd line....if you have an amdroid phone or tablet, you can install mwatch. dont have to record anymore, all past program can be found on it.
New FTA TV channel in Malaysia specialising in Korean content
should be possible, channel 104 for hankuk tvare we able to receive it in SG too.
how to? unless you stay near JB.should be possible, channel 104 for hankuk tv
I am able to receive the channel. However some of the channels not stable, keep hang.
