Anyone here staying in 2 room BTO?
Should we move it to HomeSeekers and HomeMakers?
  • Total voters
    49
  • Poll closed .
audiovideo
after hacking wall, tomorrow will put back/ replace some vinyl, pray the contractor do a good job. 🫣
flowerpalms
My Fridge like very small. 225L cannot put many things
Just look inside the compartment will do. Fridge shld not take up too much space for small kitchen
Got chilled, frozen, ice and egg tray .
The sharp 2 door is sufficient
Groceries buy weekly
The_King
ur house so noisy until need this?
u see the protruding, this 1 will take up space tho. :(
no i wonder can be made as double glazed windows
if HDB know how to think, they would give ppl option to install double glazed windows. which really help to keep our home cool
wongminmin
ur house face west sun?
can install window film to reflect the sun light......but house will not be bright.
The_King
no, windows film not as good as double glazed or triple glazed windows
let say u have double glazed windows. the heat outside will not be able to heat up from the windows due to double glazed windows, if HDB also Insulated their wall then firstly:
AC runs less often
Indoor temperature stays stable
Lower humidity swings
Less wall heat “radiating back” into the room at night
say u on AC and switch off say 10am, by 6 pm your home will not be warm, it will still feel cool thanks to double glazed and Insulated wall
too bad HDB cannot make it.
wongminmin
AC runs less often
heat will still transfer via double glazed but at slower rate.
window film works, can reflect up to 90% of the heat..... However, the frame will also transfer heat to indoor.
i got this idea from full window office or those non aircon full window warehouse.
this is another tip for u.... if ur room is hot.... i will open window...and let it cool down before turning on aircon. this will help to save some electricity.....
The_King
here my result with aircon added
for mr double glazed better as i on aircon daily
i always do airing (as in let the cool fresh air enter the home) before turning on aircon
