Oppo Find X9 Series
langford
After reading some news online, seems that Oppo might also launch the FX9 Ultra globally.
Skyy
I dont think telco able to activate the warranty. It will only be activated when connected to a network, meaning u need insert sim card. The warranty likely is activated when the buyer is checking the phone condition and they insert sim to check as well.
no need sim card, once connect to internet, it'll be activated. mine was also a telco set. the shop guy opened it up, connected to wifi, then activate already. although i protested, he said no choice, must do it.
stupidog
Is there any similar functions like this for Oppo X9 Pro (or androids) to track kids hp location?
get mili mitag or ugreen finetrack g, it is similar to airtags.
i have both ios and android versions in all my bags and luggage
tohchr
i use kaspersky to track....not free though but accurate location
can track also phone use how long a day , access what apps etc
Wow.. over track for me. I just need the location will do. :ROFLMAO:
dappercivility
Found some interesting features like able to select image to make into whatsapp stickers on the X9 Pro. Similiar to IOS and ONEUI. However the battery drop seems faster than the X300 Pro. Maybe need a couple of days to settle down.
KeYoKe
I shared previously already. X9 Pro battery don't feel like it is a 7500 mah at all. It indeed drops faster than x300p
tohchr
My smart devil privacy TP arrived. Very good quality and the edge nicely for the grey colour free casing. Fingerprint scanning worked similar to the factory screen protector.
tohchr
Everything is on smart mode. No difference brother.
I take those reviews or battery drain tests with a pinch of salt. I owned both phones, and my experience tells me otherwise.
Ok bro. You own both phones, u should be correct. But for me, the battery win iphone 17 pro max big time.. This become my main phone now as I off work with over 60% of heavy usage daily.. :rolleyes:
Shadowz1984
Those reviews sometimes is using china sets. So the optimization can be different.
