SMB sharing has been known to be vulnerable for years. It's long overdue for MS to disable it.recently the 25H2 updates caused my sharing to be broken. Use to be able to share folders between the PCs in my house and also printers. After update, cannot share liao..
After google and trying all the methods, cannot be solved. Got comment says Microsoft purposely remove the ability to share for "enhanced security".. really kns
switched back to 21H2, then back to normal
even those supposedly userfriendly linuxmint not easy to sue?if i had to switch, i would just switch to Apple macbook.
Linux is a b.tch to use ... for a normal consumer device.
For normal people who are not programmers, please just switch to Macbook.
yes. unless you only interested in opening up your browser.
if not, most programs are programmed and marketed to windows machine or apple machine.
if you enjoy spending your time finding alternatives apps (and usually end up a disaster) ..
or you enoying tinkering with the machine (UI or cmd prompt) just to get something done...
and then waste a few hours when you could have just gotten straight to the work or entertainment or whatever you are doing.
linux is for IT people and probably data scientist only .. it's a very niche use case.
got nice explanation from this video ...
As long you are a little techie. You can use Linux. You don't need to be a programmer. RTFM.if i had to switch, i would just switch to Apple macbook.
Linux mint is user friendly. I have not touch the command line for a long time.even those supposedly userfriendly linuxmint not easy to sue?
is it the most user friendly?Linux mint is user friendly. I have not touch the command line for a long time.![]()
Why I code I cannot use Mac?if i had to switch, i would just switch to Apple macbook.
Not sure why there are people who just want to inconvenience themself to use a CLI tool. There's still terminal on the Mac. Ultimately, the GUI helps in terms of productivity.if i had to switch, i would just switch to Apple macbook.
of course you can.Why I code I cannot use Mac?
Even most programmers use Mac nowadays.
Yes, one of the most user friendly distro. You can try.is it the most user friendly?
was tempted to install but to lazy too. so stuck with windows 10.
