Be careful when using laundry pods
XCalintz
is this common sense?
If the pods stick tgt, then use 2pods for heavy load? Then die die dont need to separate?
mosmos
High Honorary Member
The plastic pod case dun melt completely in water, will stuck in washing machine filters
Newtype_com
Sounds like user issue to me
BBFA like me have very sweaty patches on my armpits and crouch area
So far using the laundry pods + high temperature washing has helped me gotten rid of the sweaty smell on my clothes
Wearing my SAF Admin T Shirts with pride! 😊
Yuripa
I have been following this emergency room doctor on facebook to gain more knowledge.
The latest reel I saw was a warning he gave about laundry pods. He said these pods sometimes stick together and when you try to separate them, the pods will burst open and the liquid detergent may shoot right into your eyes. He saw a few cases that ended up in the emergency room.
So folks, be careful when you use laundry pods.
Just use powder or liquid
Problem solved
Level42
I have used 3 in 1 tide pods for the past 10 years.
Just throw one in each time I need to wash. I only keep a small box of powder detergent for ad hoc washes and that lasted me a decade.
Never tried Tide laundry pods, but you just gave a convincing testimony.
TopGun
Adding on.
I used tide pods on a front loader. Tried different combinations. Room temperature wash, 30c 40c 50c etc. Quick wash at 15 min or longer washes from 45min to 1hr plus.
No issue with cleanliness or machine. Only thing to watch is to apply common sense. If I ever have to wash 1 or 2 pieces or very small quantity, I will throw powder directly into the drum. But this is rare since I almost always wash with a decently sized load.
Taloona
why even try to separate the stuck one? Just dump the 2 together in the wash lor?
ya exactly right? just take the cup, same like rice like that. scoop, pour inside. toss clothes, press wash mode.
3 step process. why complicate your life.
I like to try new products and new brands when it comes to household products. Compare and see which one(s) I like then I will stick to the few brands. I have a combination of pods, powder and liquid detergent.
The liquid detergent (more concentrated) is to soak really dirty clothes. The pods are for machine wash and powder to wash toilet floor, wall, shower screen, sink and the toilet bowl/cistern.
Taloona
OCD lah. See 2 pods must separate them. Anyway, even with a full load, 1 pod is enough as the clothes we wear daily are not very dirty.
Taloona
Stick together yes.
Detergent burst out yes.
Shoot into eyes, no. That sounds plausible but highly unlikely. You need to be holding the pods really close to your face for that to happen.
I think some people do that, that is why they end up in the ER, according to the doctor.
Taloona
The traditional wash clothes with a wooden stick by the river is still the safest. Wisdom of the ancient people
And using the traditional broom to sweep floor is better than vacum cleaner or robot cleaner hor?
eAtNeAt
He got advise against opening the liquid detergent too forcefully in case some spash into mouth anot
OutBreak
Pods are bad for washing machine but why everytime sold out? Why ah?
whatheheck
I remember seeing some seller stream before sell those 4in1 ,5in1,6in1 laundry pods. then they say if don't like the softener etc , just cut the rest and throw the softener portion away . a bit look :s13: lidat also have danger of squirting the liquid out when cut etc
boxer33
Anyone after washing have black seaweed substance after wash or dark clothes have white residue stains?
Some say the 'seaweed' is caused by softener & white stains from powder detergent.
My top-load washing machine is new so cannot be drum dirty.
My old front-loader (which is spoilt) didn't have this issue.
