Oppo Find N6
BradenHeat
Interestingly, i found a good method to ensure the phone is unfolded without issue
need very strong magnet sticker on the case you have, plus the Aulumu 360,
shadowpartner
Anyone have a dent on the left half of the inner screen, at the top near the crease? I just saw it on mine and found someone else online with the same dent:
Vulpix
Moderator
Moderator
Uh maybe I am blind, can someone circle the dent?
Apparatus
Cannot see clearly. I suggest you wipe the screen very clean then bend it towards the light such that the dent can be seen clearly. Take a picture and post here
BTW, can your finger feels it if you run over it? If no then ok lor after all it's supposed to be a no-feel crease mah
