This midea aircon can remove workmanship issues
The_King
this guy give me idea, since my bedroom is just 1 door away from the toilet, i can wall mount the bracket on the toilet celling or wall then put this on my room
testerjp
So zho dang. What a stupid design.
You pull here and there the hose may just Crack faster.
Krabs.
the refridgerant got pressure .... can go into flex hose ah
zzzzzzz
starmext system 1 with installation around $1,2xx nia
this protable unit how much got cheaperer than starmex?
:frown:
chaiscool
:frown:
No leh moi design is hidden pipes so if want to change need reno. Easier to get such system for a room. This is good for single purpose.
Won't your toilet be hot though? How much in SG anyway. Also, compressor no need power plug, seems like only indoor unit need power. The water drain also just leak outside, sure kena complain by neighbor haha
Nuclear Boy
Very versatile, perfect for somewhere like my room. But...
This is Singapore leh... That external mounting needs to be HDB-approved... You gonna do that yourself?
Most places, you can't even hang laundry racks out of non-designated windows, let alone an aircon compressor sitting right over the window sill or ledge. :s22:
Ethan_
Think modern home come with aircon ledge can put there without approval right? And maybe try extend the piping to whatever room somehow?
Ethan_
Think that's why put toilet maybe more suitable. The water can drain out through the toilet drainage and the hot air can blow dry the toilet which may be wet when use. :s22:
ceestudent
2rm already very small space yet want to put this in the floor?
Aiyo. Just work ot or do grabfood for few days can earn enough to install system 1 properly leh. Worth it meh.
The_King
it mean hot and dry air in the toilet which mean no mold and if hang clothes in toilet, it will dry very fast
also if at toilet mean water drain in toilet also
DragonFire
Is this being marketed here? It is a much better unit for spot cooling than wheel-in duct out AC units without dedicated process air lines. I'd get a couple in the blink of an eye.
ceestudent
You sure the compressor air is hot and DRY?? Aircon make your room cold and dry.
Both input and output air is dry, then where is the humid air going?
