Eight Home Internet - 10 Gbps
BBCWatcher
Thanks for sharing. So you mean those $400+ routers have more powerful cpu/ram than asus BT10, to be able sustain 10gbps lan speed?
I had the impression BT10 was a top tier router from asus given the price point
….Another factor is what you expect that CPU to be doing. When you start configuring routing, firewall rules, and various other functions the processor may only support a fraction of the notional rated line speed.
Do you prefer speed, safety, functionality, reliability, longevity, low cost? There are trade offs.
RICO8607
Yes, Asus ZenWiFi BT10 has a slower CPU (BCM6764L or BCM6765), similar to Asus RT-BE92U.
Only the higher end ones use the flagship BCM4916CPU, like ZenWiFi BQ16, ROG GT-BE98, RT-BE88U and RT-BE86U.
Asus likes to use lower end CPU on the ZenWiFi series, like the older Asus ZenWiFi XT8, which uses the same low end BCM6755 as the low end RT-AX56U. Then higher end AX router like ROG GT-AX11000 and RT-AX86U will use flagship BCM4908 CPU.
ZenWiFi XT12 and ET12 do use flagship BCM4912 CPU, like Asus ROG GT-AX11000 Pro, ROG GT-AX6000 and RT-AX86U Pro.
Hi XiaoFan,
I would like to ask if the BT10’s CPU could be the reason why the 10G connection on the ASUS built-in wired speed test only reaches around 5.5Gbps. Under normal conditions, should it be able to reach around 7–8Gbps?
I’ve seen some users getting about 8Gbps on the Eero Max 7 using its built-in wired speed test, so I’m wondering if this difference is due to hardware performance.
Thank you for your advice!
Hi XiaoFan
Yes the built-in OOkla SpeedTest results are affected by the CPU.
On the other hand, that test basically has nothing to do with the speed of wired and wireless client devices.
When you have a proper 10Gbe Network Adapter on your PC, you will get similar 8Gbps when connected to the LAN port of either Asus ZenWiFi BT10 or eero Max 7.
If you have already Asus ZenWiFi BT10, no point to switch to eero Max 7 which has much worse firmware features.
The CPU will affect things like VPN client or VPN server performance.
keenklee
IMHO.
I hope I can reach those speed with my D-Link DPN-BE7212GR :ROFLMAO:
Now is about 4.3Gbps up/down using 5Gbe.
SpawnXp
eight here i come!
goodbye simba.
NLT on monday, hopefully can do fast fast.
thank you eight for 0.80$ first month, and time to sell the eero max 7
Edz_Sg
eight here i come!
goodbye simba.
Please share how's Eight after you installed Eight.... i still got time till sign up with Eight... Simba will charge me another month since they say 35 days
SpawnXp
currently using Asus XD6, thinking should reuse it or use the eero max 7
any thoughts on this ? @xiaofan
SpawnXp
Do you use any special FW feature of the Asus?
now its running as mesh setup.
as my room is right behind the kitchen and the main mesh is at entrance.
desktop is wired up to the mesh .
dont think the eero can work with asus.
so looks like im either stuck with the asus
or i buy a wifi 7 usb or pcie card
Windowlover
Switch over need to reconnect home WIFI box ? Current 5gpbs ,, still sufficient for all member usage..
keenklee
eight here i come!
goodbye simba.
IMHO.
I was reading at Simba thread you mentioned CGNAT, is that the only reason you come over ?
Anyway, welcome.
keenklee
IMHO.
Care to share why you come over here? Anyway, welcome.
keenklee
yeah cgnat, im hosting my own jellyfin and cannot stand the cgnat
IMHO.
Yeah, non-cgnat is one reason why I got Eight. For the longest time, I have been wanting to host something. Now my Wireguard server is within reach. (y)
SpawnXp
IMHO.
oh and i cant properly seed my torrents.
make my ratio tank alot.
lucky i got huge buffer
Starhub itself is still a strong competitor to eight Home Internet.
For non-tech-savvy users, I wil still recommend Starhub and not eight home Internet.
From the sticky thread.
⚡️💻 [Official] README First! 2026 SG ISP Comparison & Latest Promo Deals! ✨
https://forums.hardwarezone.com.sg/...sg-isp-comparison-latest-promo-deals.6665380/
1) Starhub offer for new users -- you need to contact Selina using WhatsApp at 81161630. Existing users may also sign up as a new user but the digital voice number may need to change if you have digital voice.
5Gbps Broadband @$29.55/mth
- 1x Free TP-Link HB710 WiFi 7 router
- Free $100 Shopping Vouchers -- upgraded to S$150 vouchers.
10Gbps Broadband @$44.49/mth
-1x Free TP-Link EB810v WiFi 7 router
- Free $250 Shopping Vouchers
10Gbps Broadband @$33.59/mth
-1x Free TP-Link HB710 WiFi 7 router
-No Voucher
Installation and activation fess waived
*24 months contract
2) Starhub new home offer:
https://www.starhub.com/personal/forms/hubbing/new-homeowners.html
3Gbps with free HB410 at S$29.55 per month, S$50 voucher
5Gbps with free HB710 at S$29.55 per month, S$150 voucher
10Gbps with free EB810v at S$44.49 per month, S$250 voucher
