剑桥图灵子 - 字节AI编程分享会:2026年末人类程序员灭绝倒计时:99.9%代码将由AI接管
DigDub
Vibe coding makes it very easy. Use natural language to make a webpage or app within a few mins. Coders and UI designers are in real danger.
Litmuss
The same coders who develops AI who replaced them.
randyap
I'm a coder myself. I'm not sure how realistic this is. It looks very nice on the surface but when issues comes up, you don't even know where to start to rectify. I'm also very sure after comparing, the efficiency of my code is way better than the AI's version.
The_Davis
High Honorary Member
Deluxe Member
You tell your boss that they will tell you to use AI
fortunecat
Really sia, I made 2 apps (web) past the past two weeks, very fun.
tootired
JadeWalter
wat will happen to davidktw?
will he get replaced by AI?
got passion also no use.
Mystyque
for non-critical functionality, yeah. But currently quality of code isn't something that can simply be deployed into critical areas without human checks.
By end of 2026, doubt it will be capable of replacing even 50% of experienced coders. 99% of fresh grads maybe :o
