Jurong640
any downside if i were to activate wifi calling?
The pros is it allows you to make clear voice calls with weak or non-existent cellular cover. Meaning those in office with bad simba network can leverage on their office wifi to make the phone call (I'm not referring to WhatsApp calls - an actual phone call)
Downside is actually none.
natas
I can think of one potential downside: turning on Wi-Fi Calling (VoWiFi) may give your mobile carrier a little more information about you and your geolocalized habits.
Dun turn on your mobile. Once u turn on, there is no privacy. :D
A7997A
Connecting to the cell tower already does that, and providing more information at the same time.
Best way to avoid that is to be permanently on airplane mode :)
BBCWatcher
might as well don't own a phone.
Here's what I wrote: "...turning on Wi-Fi Calling (VoWiFi) may give your mobile carrier a little more information about you and your geolocalized habits." That's a factual statement. Yes, your mobile carrier gets information when you connect to their cellular towers. Wi-Fi Calling is another source of a little more information.
Some people are interested in reducing the amount of information they share. Some are not. There's no right or wrong answer here, and I'm not trying to answer this question for you. I'm just explaining the reality of the situation, that's all.
nuscape
this voWifi is not available on Android correct? coz I don't see vowifi/ wifi calling option, at least on Oppo phone.
btw, I can see vowifi option when using other sim eg. eight.
Jurong640
yes vowifi have been on android for the longest time.
you need to go SIM settings > Wifi calling > call over wifi.
I'm not sure for oppo as i don't have oppo, definately have
hwsstx
My OPPO Reno 12F doesn't have WiFi Calls enabling switch.
nuscape
as mentioned other sim card will have the option appear in the setting but not with Simba sim card/ eSIM.
I know where the vowifi setting on Oppo phone is located. I tested with Oppo N6, X8 and X9. all don't have. It may be Oppo specific but also weird why only Simba card have issue?
even I tested with Umobile Malaysia the vowifi option is available on Oppo phone.
A7997A
Wifi calling also need phone firmware support.
Your phone likely don't have such support for Simba
(Yes, it is required per telco, basically the table in the phone don't have an entry for Simba)
Jurong640
BREAKING:
Simba just turned on 5G SA.
My phone is now connected to 5G SA and having Vo5G
