Applecare+ for iPhone
Jirachi
As far as my current company one, current generation no discount. Previous generation yes.
I get what you mean, I think something changed. I don't see mine for the latest generation (as of 17 Pro period)
froztheart
If bought from SingTel. Then later want buy applecare must go Apple Store?
Jokes aside, AC+ is purchasable when checking out on ST but I believe not after.
So you will need to either buy it through your device with 60 days grace period or Apple Store after 60 days grace period, but that is if your device is well kept and passes the diagnostics.
froztheart
if got AC+, repair can be done on get back on same day?
Subject to the issue of your device, parts availability, what time you drop the device.
Simple issue like screen repair etc. generally, within an hour/same day from my recent experience. Complicated one will be advised by Apple staff.
Or the simplest way as per Apple is to pay for the express repair where Apple will send a replacement device, and you send in your damaged device but pay the new device holding fee.
Navillera
hi all, do you all still wait for 60 days later to buy AC+ or you bought immediately?
I buy together with my purchase because I don’t use case, only screen protector. If anything happen during the 60 days hahahaha
froztheart
Doesn't matter since the start date of coverage is from the day your Apple device is turned on AND activated.
Edit:
Okay, I stand corrected. It's date of purchase instead!
But yes, if power on but never connect to network to activate will not trigger the 60 days countdown.
KingOfSbw
oh theres changes now? The last i bought is for IP16PM, it started from the date of purchasing the AC+, though
iI got that phone sometime in Sep 2024, waited 60 days before buying AC+, and AC+ is still currently active till Nov 2026
reddevil0728
This one diff ppl diff risk appetite. Is about your risk appetite that’s more important right?
I thought they changed it to when you purchase for sometime liao.
froztheart
ehhh, IIRC I turned on but didn't activate. Then subsequently activate and then AC+ started from the day I activated leh not from when I purchased.
Wait, let me check again.
Jirachi
I remembered they changed it to the day when you purchase the AppleCare+. That was the old version
froztheart
it starts from the day you purchase the AC+, not date of device activation.
dawntime
Buying AC+ from Apple direct is strictly 60 days or does 365 days window still work?
