snapdragon acer laptop if they drop to $900 will be a good buy for this purpose. 32GB ramHi there,
For a normal non gaming home user (web browsing, light office work, AI) , any minipc or laptop to recommend? Thanks in advance!
Budget? Running AI locally would usually need a good gpu with enough vram..Hi there,
it seem AI by TS means normal copilot, chatGPT, gemini, those run on the cloud one.Budget under SGD 1k?
By AI - I mean just normal usage of Claude, ChatGPT etc.
unfortunately recent ram and storage pricing has caused chaos for pricingHi there,
Just get a laptop will do. lenovo or Acer will suit your budget.Hi there,
wow nice prices u got there..unfortunately recent ram and storage pricing has caused chaos for pricing
previously, a $200-$300 mini pc would be good enough for your usage requirement
managed to buy a refurbished mac mini m2 for $400+ from apple website, but they recently increased prices across the board, even for refurbished section
https://www.apple.com/sg/shop/refurbished
lenovo outlet had some refurbished t14 gen1 at $400+, but OOS at the moment
https://www.lenovo.com/sg/outlet/en/laptops/
now, "cheapest" ok laptop is around $500+, one example below
https://shopee.sg/-2026-Latest-With...-WUXGA-Display-8GB-RAM-i.60315503.28470648848
if you don't mind mobile OS, some android tablets or ipads support display output via type-c, typically start from $300+, but note limitations compared to desktop os
i bought almost the same in Amazon last month . aoostar g flip ryzen barebone ryzen 7 h255 for $395. The non screen version aoostar was $385. You can take it as a reference point for pricingI do not want to create a new thread for recommendation. So i posted here;
What you guys think of this mini pc?
https://www.amazon.sg/gp/product/B0G69TQYFM/
is it okay or there are better buy?
Thanks. So you bought the flip? That is cheap compared to current price. So far how is the unit?i bought almost the same in Amazon last month . aoostar g flip ryzen barebone ryzen 7 h255 for $395. The non screen version aoostar was $385. You can take it as a reference point for pricing
wait for prime bah or monitor if there is any drop before prime day, sometimes the best deal are before and not during primeThanks. So you bought the flip? That is cheap compared to current price. So far how is the unit?
Should i wait for prime days in 2 or 3 weeks time?
I suppose u want a brand new set ya?Hi there,
Recently I've seen sellers putting the tag "AI Compatible" for some of the laptops they are selling... I suppose these are the ones that suit this purpose?it seem AI by TS means normal copilot, chatGPT, gemini, those run on the cloud one.
i dont think need beefy hardware. even those old used thinkpad laptop will be good enough.
Temp quite good. What OcuLink dock so cheap? can share?wait for prime bah or monitor if there is any drop before prime day, sometimes the best deal are before and not during prime
5 inch lcd touch screen nothing to shout about la, but quite handy
thermal are quite good as it has a VC with two fans. So far my CPU temp is 38 degrees celsius and if i play total war warhammer on the 780M it goes up to 56 degrees , game on it for 4 hours straight
also tested the oculink port with a external oculink dock i bought for $37, working fine
