Introduction to the world of headphones
widget
any recommendation for close headphone? budget anything below 300. looking at a900 is that good?
For home use or portable?
For home, can try DT770.
For portable, can try Audio Technica ES7 or ESW9 if you willing to go above $300.
BurntWind
i am looking for a new headphone after the ipod headphone went down the drain..
bose in ear headphones vs sennheiser cx300 in ear headphones vs sennheiser (model cant remember..cost around 42 bucks)
which one is better in terms of bass and value for money? not sure whether the more you pay, the better quality you get for headphones.
Lolicious
thanks for the recommendation! just got myself a w1000 =) aiming yamamoto amp next
angel99999
in ear are earpiece not headphones leh..
From the 3, i would suggest CX300.
Kakuza
any1 know where to find a cheap CX300? I see the shops all like $140++
beary2teddy
Hi, can someone recommend me a headphone for outdoor usage (budget 100-200)
Looking for one that has a moderately strong bass, light, comfortable and of cos with good sound quality
THX!
kopfowler
Looking for headphone of this models
Brand : Sennheiser
Model : PX200 / PX250
Colour : White
Can someone help?
on price and any shops that best to make inquiry on the models.
Thanks
dudepunk
hello i'm looking for headphones that arn't too big.. listen to mostly pop/rock stuff..
the grado sr80's operating principle is open air, what does that mean??
when i'm listening to my headphones in the mrt others can hear the music i'm playing too??
oh yes what about the Sennheiser PX 200 any reviews form the gurus here??
VelociRaptor
Yes others will be able to hear it quite well. Also you would have to turn up the volume quite alot to hear anything as it dosent block out any noise form the mrt. Might damage your hearing in the long run..
dudepunk
ah i see:o thanks.
so for closed air not too flashy ones any recommendations?
wiShfulStone
Would the audio technica fc5 or sj3 be better for a pair of budget headphones? I prefer more bass :)
LycosaEx
anybody know whr get this http://www.razerpro.com//index.php?option=com_content&task=view&id=37&Itemid=48< S$62?:s12:
anyhowsaysay
Ban leong is the distributer for razer..
maybe check with them? i think most likely can find in those pc show..
but actually you can get better quality by going for other price instead of getting razer
LycosaEx
what u recommend i get then?i wan to be like sealed up with the lubber thingy and the other 1 not
bobby29
i onced used them before and find that SJ3 have a better bass. Nicer then Fc5, but too bad i nt using them now, since i got my MS 1 =)
wenasong
Gn to Jaben Network in Adelphi near funan. They sold mid to high end earphones or headphones there. Before you buy, can try first with your own devices or amp. They also provide ordering if your earphones out of stock. Custom made earphones also available, can cost you $2000.
silverlining
Does anyone have any idea if Sennheiser MX 660 is avaliable in Singapore? If so, how much does it cost and where to buy?
TIA :)
