List of Freeware
BlackCube
Product Name: Xinorbis
Website: http://www.freshney.org/
Product Description/Features:
Xinorbis is a simple but powerful hard disk analyser. Using a sophisticated mix of graphs, tables and tree displays, it gives the user a complete overview of the contents of a hard disk (or directory). It makes it easy to see the contents, structure and file distribution and file composition of a whole hard disk, directory, or mapped network drive. Includes full report creation.
  • Analyse a single drive / directory or merge several together in one report
  • Complex report generation, with export to HTML, ASCII, CSV or XML
  • Save reports and compare them to see how the contents has changed
  • All information displays are completely resizable for ease of viewing
  • XP style support
  • Improved speed
  • Shell support, scan a directory through explorer!
Product Review: NA
BlackCube
Product Name: ALSee
Website: http://www.altools.com/
ALSee-main-browse_01L.jpg.ashx
ALSee is simply the best picture viewer for real people. Everything you need to view and edit your digital camera photos is in ALSee. There's no feature bloat with things that nobody uses or understands. Opening, viewing, editing, and saving pictures has never been faster or easier.
  • Picture Viewing
    • View 23 Picture Formats
    • Slide Shows
    • Browse, Zoom & Edit Modes
    • Perfect Printing
    • Convert Picture Formats
  • Photo Editing
    • Cut Selected Area
    • Red Eye Removal
    • Stamp
    • Resize & Rotate Pictures
    • Overlay Pictures & Text
    • Word Balloons
    • Picture Frames
  • Advanced Functionality
    • Pixel Info Viewer
    • Batch Conversions
    • ALSee Photo Library
    • ALSee Movie Maker
    • Batch Rename Pictures
    • Thumbnail Size Control
Product Review: Just a simple review. I wanted to batch rename almost 10 000 images inside one of my directory. If I were to rename it one by one, or using the Windows method. It would probably takes a long time or not something I want in the end. And ALSee managed to rename my images of 10 000 just within 3 minutes or so. That's really fast.
Extra Notes: FREE for home users only.
BlackCube
Product Name: LoadScout
Website: http://www.loadscout.com/
  • Show instant info about any media file on the web
  • Play snatches of remote MP3 and AVI files
  • Browse remote archives without downloading
  • Extract individual files from remote archives
  • Powerful download engine
  • Internet Explorer integration
Product Review: NA
BlackCube
Product Name: Gizmo Central
Website: http://arainia.com/
  • Mount password protected images to a virtual hard drive
  • Encrypt HD images using a passphrase
  • Protect vital files from hackers using encrypted HD images
  • Mount IMG files to a virtual drive
  • Mount and unmount files from the Windows Shell
  • Mount and unmount files from the command line
  • Support for compression and sparse HD images
Product Review: NA
cnt
EASEUS Partition Manager 3.0 Home Edition - FREE FOR HOME USERS ONLY
http://www.partition-tool.com/personal.htm
* Resize, Move partitions without losing data.
* Disk Copy, Partition Copy to protect data.
* Copy with Resize to fit target space.
* Create, Delete and Format partitions with simple step.
* Hide and Unhide partitions.
EASEUS Disk Copy
http://www.easeus.com/disk-copy/
Major Features:
* Copy all of your hard drive: Creating a bootable CD/DVD, it allows you to copy entire disk in case of unknown/proprietary file systems.
* Partition copy: Enables you to copy one partition to another partition you want.
* Disk copy: Enables you to clone one disk to another sector by sector.
* Sector by sector copy: Makes physical 1:1 copies (clones) of hard disks and partitions. This ensures 100% identity to the original.
* Safe, simple and fast: It is a very fast and easy way to copy all or part of a hard drive to another hard drive with Disk Copy.
More Features:
* Supports inaccessible disk copy
* Supports booting from CD/DVD
* Friendly graphical user interface
* Relay disk space for insufficient destination
* Support hard disks up to 1 TB
percivale
Thank you TS for such a good initiative and providing members with the list. I have a few suggestions:
Winamp
Faststone Photo Resizer
Picasa 3
Safari 4 (Beta)
theoryjack
Product Name: PCLoginNow
Website: http://www.pcloginnow.com/
  • 100% recovery rate
  • Reset Windows logon passwords.
  • Change account to administrator level.
  • Lock/Disable Windows Accounts.
  • Set passwords to never expired
  • Support syskey.
Product Review: NA
this is no longer free liao. last checked 5mins ago.. jus tot i should let everyone know.. :)
sg_ltech
You can follow this guide on how to read and type chinese words.
If you do not understand any part, do feel free to ask.
tks for replying, do u know of a software or is it a XPchinese version, that when i roll over my mouse onto an English word, it will show chinese wordings?
BlackCube
Sorry for the late reply. I don't think so.
ASM_HWZ
Another alternative to Outlook... The SpiceBird
Spicebird is a collaboration client that provides integrated access to email, contacts, calendaring and instant messaging in a single application. It provides easy access to various web services while retaining all the advantages of a desktop application. The application is based on projects like Thunderbird, Lightning and Telepathy and adds more functionality and integration among its components.
nuttyazn
There is a Shareware called DR. Eye that does that:
Achieving Instant translation by sliding the mouse and supporting mutual translation in Chinese-English and English-Chinese
http://www.dreye.com/en/
