List of Freeware
mercuryscio
went through cnet and only manage to find trial ver, anyone able to recommend free keylogger apps.
aptget
thks for the reply, just manage to find one freeware program which allow converting the selected folder content from bmp to jpg or gif etc @ a single click. save alot of time. :D
i think command line can do all that right ?
ComputerTime
Another very good chinese input is 紫光华宇输入法 by the name of unispim.
http://www.unispim.com/software/index.php
It supports full win7 64bit input and has predictive texting. Also auto downloads new 词汇 into the 词库. Fully free too. Been using it for 2years, no problems so far.
If you are using Windows XP and later, the Chinese input is included in the OS. Just add in Chinese (PRC) into the Language, and select "QuanPing" and "ShuangPing" as input. This will enable you to input Chinese. No need additional software.
satay16
but the prediction is quite lousy for windows built-in. have to virtually type out the whole pinyin for it to recognise properly.
NWT1978
Cryptainer LE
Cryptainer LE is part of a suite of security products offered by the company that works on Windows. The LE product is their free version which offers some compelling features such as:
Disk encryption for files and folders (Blowfish algorithm)
Creation of secure email attachments
Virtual drive that appears in Windows Explorer
Passwords from 8 to 100 characters
The other item that distinguishes Cryptainer LE is that it has a component that can be loaded on to USB drives called Cryptainer Mobile. This means you can carry your data on the thumb drive without needing a program on the host computer to decrypt. The one caveat is this doesn't work with Windows 98 and Windows ME since those operating systems don't auto load USB drivers.
http://www.cypherix.co.uk/cryptainer_le_download_center.htm
rockyy
Not sure if this was highlighted earlier.
You can get almost all the freeware you need at this site :
http://www.filehippo.com/
You can keep coming back to this site as she updates to the latest versions of all the freeware.
:s22::s22::s22:
laurenspang
any freeware to help recover corrupted data fr an ext 3.5 hdd?
eg. the file names has become jibberish and vid files cant b open,even if can open,it only plays for less than 10secs and it stopped
rabien
I like to use Ultradefrag as well. for disc burning I use InfraRecorder with a really simple layout. For image editting, I have no idea why GIMP and GIMPhoto would be left out of that list =P
Video converter: http://videoconverter.hamstersoft.com/
I prefer Format Factory but hamstersoft has an AMAZINGLY easy and neat UI. For changing fileformats to be played on any PMP, I would go for it.
If you need to encrypt files or folders, try TrueCrypt =)
All my personal favourites list =)
Cissiboy
for photoediting i cant live without Paint.net and its plugins. Gimp's interface it's too unfriendly for me
yameen
Vdownloader can download and convert video( Mp4, AVI, format ) from youtube
seojulia
List of freeware
Hi,
I like this post very much, I am interested in enhancing my knowledge related with any technology update, and IT knowledge.
Many freeware like video download, photo editor, are very helpful for you.
It's a great freeware resource site.
thanks for sharing it with us.
