looking for any free ware to type Chinese character. something like Nj
thanks
you can download google pinyin. just search from google.
thanks
thks for the reply, just manage to find one freeware program which allow converting the selected folder content from bmp to jpg or gif etc @ a single click. save alot of time.![]()
i need something that can be use on fire fox & Microsoft office.
try google pin yin only for ie
any??
i used google pinyin on firefox and office with no problems![]()
Another very good chinese input is 紫光华宇输入法 by the name of unispim.
http://www.unispim.com/software/index.php
It supports full win7 64bit input and has predictive texting. Also auto downloads new 词汇 into the 词库. Fully free too. Been using it for 2years, no problems so far.
If you are using Windows XP and later, the Chinese input is included in the OS. Just add in Chinese (PRC) into the Language, and select "QuanPing" and "ShuangPing" as input. This will enable you to input Chinese. No need additional software.
is this good?
Cryptainer LE is part of a suite of security products offered by the company that works on Windows. The LE product is their free version which offers some compelling features such as:
Disk encryption for files and folders (Blowfish algorithm)
Creation of secure email attachments
Virtual drive that appears in Windows Explorer
Passwords from 8 to 100 characters
The other item that distinguishes Cryptainer LE is that it has a component that can be loaded on to USB drives called Cryptainer Mobile. This means you can carry your data on the thumb drive without needing a program on the host computer to decrypt. The one caveat is this doesn't work with Windows 98 and Windows ME since those operating systems don't auto load USB drivers.
http://www.cypherix.co.uk/cryptainer_le_download_center.htm
