Saw mixed review on the Pogo Sketch.
- Some say this is the best stylus for iPad.
- Some say still not easy to write on the iPad.
Any feedback ? What stylus you are using ? How much ? Where you bought it ?
I am using the pogo sketch and using it with WritePad. The experience is not as good when comparing with using a stylus on windows mobile device than on ipad. The problem is not with the software or the pen but with the touch screen. Nevertheless, the stylus improves the handwriting recognition as compare with using finger.
For taking longer note, I find using a stylus is better than finger.![]()
I bought mine from www.istore.com.sg. The tip is fatter than I expected, making it feel more like a brush than a pen. It also requires quite a lot of pressure to activate, but this could be due to the screen protector.
i bought the pogo sketch stylus. Quite disappointed as it requires quite a bit of pressure to work and is very hard to write or sketch at an angle.
I hope to find a rubber tip that is more firm as the sponge like material used on pogo is not very suitable.
My friend has one with the rubber tip. He told me not to buy the one with rubber tip. It was very difficult to write using the rubber tip. He was looking for the felt tip.
For now, a work-around was he put a costape at the tip. It is smoother to write on the iPad now.
haha then i guess iDevices are not meant to be used with stylus..
Brought the ifinger stylus from SLS at $39.90 ( cheapest), the guy let me try till song song before I buy. Find the stylus not bad
This message is sent from HWZ forums iPhone app
hmm but i read reviews like not very precise, dun mind post a pic of ur note taking?
This one proven to work... you can eat it too when you're done with it *hehehe*
Buy from Amazon : http://www.amazon.com/iPhone-3Gs-Sausage-Screen-Stylus/dp/B003AKLVX2
