SingNet Fiber Broadband Installed.....
orbvius
should be able to work if u connect ont direct to pc.
someone from the other forum say ip address take quite long to get when he change devices. (but that is m1)
do your singnet have such issues? can get ip address after powercycling your ont?
xerxesrex
cannot...no ip
maybe mus set static ip..
and hopefully no pwd set
tml i will try...
bridge mode is got no ip ;) so chiu cannot access the modem in bridge mode. if chiu wanna change it to router mode, just hard reset it, but singtel may cow pay cow boo later haha. just stick wat u have now.
SaLvAtoOo
thanks.. i will try it out tml... will do a powercycle after reconnection of the cables
SGBoYxxx
no difference...feels the same
:s11: seriously you don;t feel any difference? in term of speed?
even multi pc using together? stream...suft net...download?
Happen to go singnet event at plaza sing ..they demo it..
I see seem quite ok not bad..also the mio tv now is very smooth...load youtube is fast...
and the tv apps also seem not bad..
radish
Emeritus Honorary Member
m1 didnt even bother to give me a rg
nucleus is the one tat fix up the ont and i'm connecting directly to it now
previously i was using my wireless router speed drop as much as 50-20% :eek:
if u can connect direct...bypass the behkan 2wire it maybe omgbbq :eek:
ur ont to pc direct connection can work?
i tried mine... cannot get any ip.
die die need to go thru 2wire
low latency got no use for me i dont play online games :(
sometimes speed isn;t everything
the low latency is very attractive for gaming.
SaLvAtoOo
ok im not a heavy downloaded..
youtube loading is definately better compared to SH...
surfing.... no diff..lol
SaLvAtoOo
ya.. i tink so too..thats why i m trying to bypass the 2wire..
can't get into the ont admin page etc.. no ip.
haf to google the model for the admin manual liao
t258jgn
I wonder why they are so troublesome, use so many different kinds of ONT & routers. Can't they standardize just using 1 type of modem router something like Billion BiPAC 9300VNX GPON 3G VoIP Wireless-N Gateway without the 3G function?
SaLvAtoOo
the teleco are not r&d company..
who is going to design and fabricate and mass produce such device..
somemore who is going to support it..lol
FT?
SGBoYxxx
me too...I never download just suft net...watch stream..thus lol I keep thinking if I upgrade to fibre..from adsl is it over kill :s34: somemore is not cheap too.
next download wise...overall still have to depend those overseas uploader....if their upload speed is limited...even ur download speed is fast..still will be cap at certain speed..
correct me if I am wrong here.
The_Davis
High Honorary Member
Deluxe Member
here u go
6.4mbps or 6400kbps? :s11:
