xtramadness
- Mar 4, 2009
What trial? How u get trial
is it goooooood?
i tried... cannot work. both pppoe and dhcp cannot work.
2wire's wan is configured using dhcp btw..
What trial? How u get trial![]()
bridge mode is got no ipcannot...no ip
maybe mus set static ip..
and hopefully no pwd set
tml i will try...
should be able to work if u connect ont direct to pc.
someone from the other forum say ip address take quite long to get when he change devices. (but that is m1)
do your singnet have such issues? can get ip address after powercycling your ont?
no difference...feels the same
seriously you don;t feel any difference? in term of speed?ur ont to pc direct connection can work?
i tried mine... cannot get any ip.
die die need to go thru 2wire
sometimes speed isn;t everything
the low latency is very attractive for gaming.
even multi pc using together? stream...suft net...download?
Happen to go singnet event at plaza sing ..they demo it..
I see seem quite ok not bad..also the mio tv now is very smooth...load youtube is fast...
and the tv apps also seem not bad..
m1 didnt even bother to give me a rg
nucleus is the one tat fix up the ont and i'm connecting directly to it now
previously i was using my wireless router speed drop as much as 50-20%
if u can connect direct...bypass the behkan 2wire it maybe omgbbq
low latency got no use for me i dont play online games![]()
I wonder why they are so troublesome, use so many different kinds of ONT & routers. Can't they standardize just using 1 type of modem router something like Billion BiPAC 9300VNX GPON 3G VoIP Wireless-N Gateway without the 3G function?
ok im not a heavy downloaded..
youtube loading is definately better compared to SH...
surfing.... no diff..lol
somemore is not cheap too.6.4mbps or 6400kbps?here u go
TS can please test from MU RS HF FS etc...
