bass soft? make sure DRC is set to Off (under Level menu). also, ensure DRC is off in your dvd player.
also, location of sub in room affects bass as long standing wave may have cancelled the phase within the room. try move it to another location to test out.
as it's down firing, it may not need to be near wall or in a corner for effectiveness.
Hi bro thanks for your advice after tweaking bass and everything seems to be good this are the settings i used havent check on the DRC will check it tonight.
Settings :
Sw Level : +5
Center Speaker : +2
Bass + 1
Treble + 2
Lower bass settings is to let sw handle and mid/high for my soundbar. Ct150 owners please do share your settings .
Btw on my media player i got few audio source may i know which is the best ?
Hdmi/Lpcm
hdmi/lpcm multi channel
hdmi raw
For some movies raw doesnt seem to get any sound .
