JAson1980
- Feb 27, 2006
to add on to this, be extra careful when replacing your cables.
found this video online.
ouch
pm-ed you![]()
Weird that black is actually slightly pricier?
Old packaging as in Retail Version? in fact those are better.. its is not rush out last minute mass produce product =P .. but up to individual bah.. i see a few forums most prefer retail version than the black box version.. but the L angle tbh wont break so easy for connector there because the straight one user tend to pull cable out instead of connector this cause the rubber shield to be expose..
hmm so you mean the retail version is the old one with the straight cable while the new one the black eco box is with the better L plug?
i know reshelling does... cable not sure
People .
Changing the stock cable will void warranty purposes or not arh ? Can anyone confirm this ?
buy from usa already no local warranty le mah i tot
But i remember reading here someone said warranty can bring over to SG's Logitech ?
Nope. He actually mentioned he raised the matter to US Logitech.
People .
Just got mine from bro angcsbenny earlier on. All I can say is I love the sound... Kitaro's Matsuri has never sound so good before!!
Anyway got one question to ask you all. For the reverse mod it's suppose to look like this or is it the other way round??
sorry if the image abit unclear... but basically the L/R indication on the cable shld be facing outwards right??
As for mine, it faces inside just that L side put into the right ear piece. R side put into the left earpiece
so the correct way is for it to face inside??
