[Official] TF10 Appreciation thread
shadow84
My comp crashed and word document corrupted so full review unavailable.
Short version:
Audiohub Hybrid - Sound is more musical, is clearer and cleaner. Bass presence is increased and is tight and punchy. Mids are brought forward. Soundstage is similar to stock, but the highs extensions are more refined. Personally enjoyed pop and rock genres were enhanced with the cable.
Null Audio Lune - Sounds sterile, wide soundstage with extended, sparkling highs. Bass is tight and punchy but quantity is short of the hybrid. Mids somewhat the same as the stock cable.
Notes:
-Hybrid cable is at its V2 development stage.
-Louis of Audiohub told me that the default config of the Hybrid is biased towards the warmer side, I've requested mine to be on the silver-based side instead.
-Null Audio's price is more than 1.5times that of the Hybrid, but I personally think the price to performance ratio for the Hybrid is better than the Lune.
-The Hybrid cable is not as flexible and has more microphonics than the Lune, but the overall feel so far the Hybrid feels more solid at the plugs. Louis is still working on the IEM connectors itself at this point on the ways to reinforce it.
Initial impressions of the hybrid (pre-burn in stage):
Very dynamic and enjoyable for pop and rock genres. Only after burning in did the bass really shine. Vocals are comparably more forward than the stock.
post some pics of audiohub cable with ur tf10?
shawn_sboi
I just change my tips to sony hybrid size MS and super good!
please do not get XS as it can't fit into TF10...
Damn good comfort and no more pain! going try shures olive soon!
dUStyEX99
Now trying monster foam...
Really very good! Sound reproduction is better than Olives and Complys...
Now very quiet, so cannot test the isolation...
Until now i think double flange work the best expect for the fit but the foam can fight with it and better fit...
TF10 will stretch the tip quite a bit! and the foam is not so "memory" as compared to Olives and Complys.
Gel is :s22: for me cos like insertion is not deep enough thus no seal... but that for TF10.
fullerms
What size comply tips are included with the UE TF10?
Bros,
Just got my pair of UE TF10's for Xmas, and blown away by the audio quality :). However, I am having trouble with the Comply Tips included with the set. They are too big for my ear canal, and I want to buy smaller sizes.
Anyone can tell me what size of comply tips are included with the TF10's so I order a smaller size. On the same topic, any alternate brands to recommend for ear tips?
NightFalcon8
Bros,
Bro, there is only one size for the Comply tips. You need to squeeze them before inserting into your ears. They'll expand in your ears.
x3dnd3x
Bros,
Push into your ears , hold the position for around 10 seconds . That was what i did last time when i was using complys .
x3dnd3x
His muscles dua dua liap . :love:
Short version:
Notes:
zyklon86
If I am not wrong, the stock comply supplied is medium. There is a smalle size available directly from comply. Most online places seem to only stock the standard medium size.
I too had the problem of the standard comply being too big, but using the "push and hold for few seconds" method, it fits quite ok.
Foress
anyone knows if there will be "burning-in time?" because alr sound so good if still burn in ah.. :D
xFuture
agree, stock cable . beh kan. don wste time burn if u intend to switch to other cable. :)
wacko
I checked on the comply website, there's actually 3 sizes. Thats why I ask.
if you have checked comply website, you would also have seen the dimensions of the 3 sizes. go measure the ones you have, then deduce.
Foress
noob question alert: isit possible to custom my Triplefi to make it look like this? :O
weibchen
the color is saturated to look deeper..actual color would be much duller than this.
weibchen
reshelling is interchangeable cables thats the perks to change it when it wears out or when you want a slightly different flavor to the sound.
