omnilancer
- Apr 17, 2001
I'm using 4 x Strontium rams in my imac 27'' now. So far so good
OWC ram is prohibitively expensive due to their so-called "Mac-Tested" gimmick. If you want good premium quality ram for cheaper, go for brands like Crucial and Corsair instead. And avoid budget rams at all costs.
All brands of ram have premium and budget ranges. You have to go visit their websites and check their specs. Most common budget ram would be Kingston KVR.you mention budget rams? which are the ones that are budget? Kingston? Strontium? Samsung?
I am using a mbp 5.1 2.4ghz. Read online that it support 8GB after the latest EFI firmware upgrade. Beside OWC? Any brand good to recommend?
And OWC also launched a new 30GB SSD at only USD$70. Anyone using one? Care to share the performance?
Not true, Strontium has both premium and budget lines. Their budget range is like KVR while their premium one I've not tried, so I don't knowstrontium and kingston both are value ram,if you ask recommendation in this forum most will say strontium for sure![]()
Depends. Like I've been saying, it all depends on wether you buy their budget or their premium rams.what abt samsung? are they good?
Sorry, new visitor here and second post already:
I've got a late Macbook 2008 unibody (worst Apple purchase ever, really...) and whilst it's not an amazing laptop for most things it works and I'm kind of fond of the thing and wanted to give it a little speed boost.
I will definitely get the 8Gb RAM upgrade, that's a given.
But then comes the question of the HDD. I've got a stock 250Gb 5400rpm disk in there. The options to replace are multiple and are really only limited by budget.
I don't want to spend a fortune as I could just sell and buy a later model, but I'm happy to spend say S$500 on this project.
Single options:
Single 500Gb Momentus XT
Single 240Gb Vertex 2
Single 1Tb Samsung Spinpoint F3
Dual options (if removing Superdrive):
Dual 500Gb momentus XT
Dual 120 Vertex 2
I really want to stay with SATA2 for SSDs, but I can only find the Vertex's (from Fuwell).
There's plenty of online opinions on some of the above options, but not many has a genuine comparison. I'm really thinking the XT is "ideal" but then there's alsways someone with a nagging story about "how diappointed" there were and how "much better" and SSD turned out...
why must u spend $500. I do only about $200 with upgrade to 500 gb HDD (samsung)/ maximum can use 500 only. with kingston 8gb ram and free install of lion os. my macbook same year as yours. and everything work fine and Facebook games running smoothly.
just purchased 2x4GB RAM from simplymac.sg
OWC RAM. more expensive than other brands (corsair, kingston etc) i suppose... $125.
patrick @ simplymac gave me his word that they will work with mac mini 2011. so i bought them.
afraid that other brands might have some compatibility issues. afraid of trial and error and waste $$$$!
the OWC RAM works just fine for my mac mini 2011! they have the samsung label on them.
patrick helped me to install them as well @ his convenient place!
Hi guys!! Let's just say I wanna upgrade my hdd. Is there any free easy way I can duplicate my old hdd which has bootcamp in it?
