China Tablets to recommend
seasonscrystal
so another words the vending.apk cannot just tap and install like normal apk ah?
Nope doesn't work like that. it'll be good if marketupdate.apk is in there together.
Example, if you have 3.1.5 market, you have 3.2.0 market apk. You can just update it by running 3.2.0 (at least it doesn't work for me the last time I tried it)
innovativeint
I recall a bro mentioned that the latest firmware came with market. If so just update to lastest firmware.
Official firmware
http://translate.google.com/transla...m/plugin.php?identifier=ainol&module=download
ELSE.
Try get it root, if it's 2.2 can use z4root (google it, it's easy to find). Then use root explorer, copy vending.apk which I believe you have into system/app. Do make sure app folder is on R/W. After that just reset/restart the tablet.
Edit: As all root or mod or rom update, it's on your own risk. I would ask her to go back to the seller and insist it get fixed.
can nova 8 firmware use on nova 8 advanced?
innovativeint
chim ma logy
temasekcity
For those of us who cant afford/dont want to buy ipad. what is a good China Tablet to get for its price?
I want an acceptable screen
acceptable battery life >90min
good ram/performance and 2.3Android if possible.
Come, let's share lobangs/deals :D
ipadi good for you. hot and spicy.
seasonscrystal
thanks mate.. will ask her bring down and i try for her.
BTW the market u press in vid looks like a fake market.
Also you may not have the full market even if you do what I mentioned above, as market will block all incompatible devices for some apps.
Just like Novo7A is too new, so Skype, Whatsapp, etc can be search in market as Novo7A is not being listed compatible in those apps, so market just blocks them from all Novo7A. BUT if you install via apk most still works:s8:
innovativeint
this market is very tricky, so this market base what to determine if the tab is compatible......
my side has telechip 8803 on 2 different tab, one with older market and one with new one...
new market 3.2 anything also say device not compatible while the old one is almost all can...
weird... even one of the samsung processor A8 also same issue ...
could it be google going to be like apple? any tab that are not in their approval list are not allow to download anything in future.. hmmmm
kyleongwl
i think tat where the build.prop needs to be mod...using fingerprint of certain unit will help...sansung tab, droid3 etc...however, seeing an actual running running are c differ
kyleongwl
thanks mate..
Can help me test below too which i have some prob with my A9 prototype
1. Is little bit of pressure required to get screen to respond?
2. When taping on icons "A", it opens icons "C" instead?
3. Is the speaker volume soft?
4. Does the market allow installation of "Flash 11"?
5. when you shake it hard, will there be moving parts?
6. is wifi slow?
Just wondering if this is a norm for A9 processor for now?
Thanks
1. no. its ok on screen ...but mo pressure on the side toolbar
2.????
3. no issue on media...games are ok...(juz as soft as my other android device)
4. InstAll n no issue
5. no loose parts
6. kinda slow to pickup n attach to network
w00tw00t
so which means release of ICS is to slow down present tablets and indirectly create demand for higher specification tablets..
in turns generate repeat business....same old strategy for software and hardware marker right?
It's not really a direct effect. They're not doing this on purpose. Consumers like you and me want more effects, more functions, that means the software guys need to come out with software that meets the demands. Fanciful effects and useful functions sometimes do not come for "free". All these needs the CPU to work on. The side effect is thus the software requiring more powerful hardware, and along the way, the older hardware are made obsolete.
From the looks of it, the A8 and A9 processors might not be powerful enough to be usable. I mean, we might be able to install ICS, but the poor user experience might force us to revert to Gingerbread. Hope not. :(
Piggyz
Hi, currently my relative is at china now around shanghai area :p .. i'm asking them to help me buy a 10 inch tablet , can u guys recommend me some of the better quality ones?
i'm looking for
1ghz and above
android 2.3 if possible
A9 or nvidia tegra 2 or anything thats around there :p
and language is english of course :s22:
i will be using it to watch movies and playing games like nova 2 etc
innovativeint
2.????
5. no loose parts
For 2. try connecting to charger, and keep taping "C" and see if it will jump out other "ABC
innovativeint
i'm looking for
1ghz and above
Even if you buy the best specification tablet also no use because the system may have incompatibility issue with the good hardware if not done well.
good luck!
koxinga
OK, more or less decided to get the M12 because got IPS screen and the battery life is good. U think better to wait until Nov? Because I think Merimobiles should have their usual XMas discount coming soon.
chrisyeo
i'm looking for
1ghz and above
酷比魔方U9GT2
http://www.ereadcn.com/bbs/attachments/month_1110/1110291554803ab3d6e0837c8a.jpg
seasonscrystal
Don't buy the U9GT2 yet. The 1st batch seems to have quite a bit of problem. Wait till they improve. Also at that price, Aoson wopad M19 would be a better deal:D
Piggyz
coz the thing is , i'm getting the pad from taobao only, and if the U9GT2 has problems .. what other pads are there? and what problems does it have?
