Any folks on Viewqwest fibre?
etherealism
Hmmm... The more recent laying of fiber isn't as optimal as the previous.
The newer fiber cores are not laid in an optimal distance due to the path used. The new core is laid in metal trunking along the ceiling of pavements at ground level of block and goes down at some specific ends of the block to go underground and crosses the carpark road to the next block.
While fiber is not as sensitive to distance as copper (due to the signal is different nature), I do two concerns:
Concern 1: Will the above discrepancy results in slightly higher latency (e.g. few milliseconds)?
Concern 2: Will the above mentioned discrepancy results in a disadvantage to newer OpCos?
1. latency unlikely to increase by much, considering that light can travel 1km in 1/299800second. 1ms by comparison is 1/1000
2. maybe of concern will be path-loss esp at the biggest exchange here aka amk
carhorn
Hi viewqwest
I have have TP installed by Opennet this afternoon.
I would like to check with u how fast I am able to hook up with internet access via fibre once I have made a application to your company?
Also how long is the fibre patch cord that is given for the connection between TP and ONT? May I have a 5 meter patch cord? =:p
viewqwest
Featured Sponsor for Internet Bandwidth & Networki
Hi viewqwest
Although the TP has been installed by OpenNet we would have to confirm if the back end cabling has been done. Once you home is updated as ready for service by OpenNet. It normally takes 2 to 3 weeks for OpenNet to activate the circuit for us. We will be able to give you a more accurate date once we receive your application.
The patch cord that we supply is 3m long. If you require a longer one. You would need to find one at Sim Lim Square.
crewcutboy
Ars Technica is loading really slowly, with lots of images not loading or loading very slowly.
traceroute to arstechnica.com (75.102.3.15), 64 hops max, 72 byte packets
1 192.168.0.1 (192.168.0.1) 1.082 ms 0.488 ms 0.400 ms
2 fnet2-f198-access.vqbn.com (103.4.198.2) 1.947 ms 1.752 ms 1.715 ms
3 202.73.47.247 (202.73.47.247) 1.808 ms 2.009 ms 1.807 ms
4 203.208.190.241 (203.208.190.241) 2.301 ms 1.926 ms 1.895 ms
5 203.208.152.229 (203.208.152.229) 1.963 ms 2.062 ms 2.047 ms
6 203.208.171.86 (203.208.171.86) 182.789 ms
so-2-0-0-0.laxow-cr2.ix.singtel.com (203.208.172.102) 194.798 ms
203.208.153.122 (203.208.153.122) 176.245 ms
7 ge-1-1-2-0.sngtp-dr1.ix.singtel.com (203.208.149.214) 184.605 ms
203.208.171.226 (203.208.171.226) 176.446 ms 197.816 ms
8 203.208.186.82 (203.208.186.82) 198.778 ms 181.199 ms 177.356 ms
9 ae1-50g.cr1.lax1.us.nlayer.net (69.31.127.129) 175.551 ms * *
10 xe-2-2-1.cr2.ord1.us.nlayer.net (69.22.142.255) 230.795 ms 225.754 ms 226.181 ms
11 po6.ar2.ord1.us.scnet.net (69.31.111.6) 234.829 ms 239.007 ms 234.293 ms
12 ge0-2.aggr3102.ord2.us.scnet.net (216.246.94.190) 239.159 ms 237.850 ms 243.111 ms
13 * * *
14 * * *
viewqwest
13 * * *
14 * * *
could you drop a line to our noc@viewqwest.com - i have tried from my home and don't seem to have an issue. Best people to help would be our tech support team.
dunbullythx
Hi Viewqwest. How much charges are needed to pay if i move house and continue to subscribe to the fibre? (Ftp installed)
viewqwest
The relocation charges are $200 pro-rated against the first 12 months of the contract.
viewqwest
Thanks for the prompt reply. I'm a no contract subscriber. Do i have to pay $200 at a go?
You have the option of paying the $200 or terminating and signing up again. In which case the new location would result in the lesser charge of registration fees and activation fees.
edwin21
13 * * *
14 * * *
same here, very slow loading or not loading, but the weird finding is direct connection (without router) works fine...
same for hidemyass.com also not working behind routers
both use the same cachefly.net server
Address: 204.93.150.150
Aliases: static.arstechnica.com
Non-authoritative answer:
however with the same router config on starhub fiber, both the page load without any issue. not sure is zhone issue or VQ connection issue
FileZAce81
Hi, did anyone got problem connecting to mediacorp radio? Can't listen to most of the radio stations.
Tracing route to radio.mediacorp.sg [202.172.178.80]
over a maximum of 30 hops:
1 <1 ms <1 ms <1 ms 192.168.0.1
2 2 ms 1 ms 1 ms fnet66-f198-access.vqbn.com [103.4.198.66]
3 2 ms 2 ms 1 ms 202.73.47.226
4 2 ms 1 ms 1 ms 58.65.16.21
5 2 ms 2 ms 2 ms ae-0.br001.sgp02.ntt.com.sg [116.51.3.137]
6 5 ms 5 ms 4 ms ge-1.starhub.br001.sgp02.ntt.com.sg [116.51.3.22
7 5 ms 4 ms 4 ms gi-4-0-0-an-atl-loc01.starhub.net.sg [203.118.5.
60]
8 5 ms 5 ms 5 ms 203.117.133.102
9 * * * Request timed out.
10 4 ms 4 ms 4 ms 202.172.223.174
11 4 ms 3 ms 3 ms 202.172.232.21
12 * * * Request timed out.
13 * * * Request timed out.
14 * * * Request timed out.
15 * * * Request timed out.
fitlies
How are you guys paying the bill? Really through cash or cheque? Any way I can pay through IB or GIRO, VQ? I wanna pay my bills but I have no time nor cheque! LOL
doki81
if my housemate just applied starhub fiber bb...can i still apply viewquest fiber bb at the same house unit?
