The Huawei MediaPad, 3G 7" tablet, now in Singapore!
edmund_gan
in ics, storage option, there is an option to set primary storage. but i didnt try it before.
You can try but selecting Sd card does not work for me.you can try and feedback. In the end I did not root it as I realized that it's the games that takes up storage which I do not party a lot of games..
Jiele2008
Hey pal, it works for me!! Now I am able to move those moveable file to sd card via app-app2sd.....!!:s12:
Bro or any kind soul know how to take a screen shot by default with ics? without using any app? Thanks..
Hanwudi
In honeycomb, it's holding the runnig apps key.
after upgrading to ICS, i'm searching for the answer too. :o
edmund_gan
Glad to report that it's working....but note that when you see under settings>storage, you will see that it's still the same even after seeing sd card to primary storage..however when I use asteroid file manager to check, the files are in the sd card already.
Now contenting to buy a 32gb sd card...but class 10 or class 4 ...any advice?
Jiele2008
Confirmed tye chop it is working. In app2sd, after moving the moveable apps, instantly I can see the increased of free space in the lower part of screen. E.g 3.5GB to 3.78GB..l:s12:
Thought of getting 64gb but just afraid it may not work...
As for screenshot. Googled and someone in xda forum said ' power key + 'up' volume(the one furthest from power key) to be pressed simultaneously. Tried, out of 10 times, 1 successful click. Timing is the key, but I just couldn't get the right timing..
Hanwudi
Like you said, I tried the 'power' + 'up' volume key serveral times, cannot work. How come Honeycomb so simple but ics so difficult :s11:
Jiele2008
Taking screen shot on ics
Hey Bro, i didn't give up and googled further. It works!!
As mentioned hold power key + volume key that is furthest from power key.this is the trick and fugging simple. Hold both keys for few seconds, that it and you will hear the 'click' sound. Done!!
Failed previously as i am expecting instant shot like my iPad 2.....:s12:
Try it dudes
edmund_gan
I just notice something on the battery consumption...it seems that wherever I off it .after 5 hours I on it, it shows that it have been discharging for the last 5 ..is it normal?
Jiele2008
Oic, so far i dont off my set,just place it on airplane mode. i would stay the battery doesn't deplete much on standby.
E.g. Days back i am down to 3% of battery life at around 1am+...left it on standby til next morning 7am+. The batt level still remains at 3%.
Anyway, bought a silicon skin meant for tab P1000. 95% fitting, need to cut the top right speaker and the usb port to expose it. overall satisfied with the $8.50 skin. Wil pose the picture tonight..
chuah23
dear all,
Just got hold of my 1st tablet from Best @ 299, upgraded it to ICS yesterday and but I did not see any phone function or sms function(I saw it in some youtube featuring ICS mediapad), does it means that I need to DL a link into the tablet? If yes, any bro got the the link can forward it to chuah23@hotmail.com, thanks
bbcccc
dear all,
went to best denki in compasspoint and its sellin at $598 lei
no $299 :(
Ender
dear all,
The phone dialer should be inside the Application.. It's not in the home screen. You can manually drag it out to home screen.
chuah23
Thankd, I will go back and then take a look, very tortise cos not very sure about android device as still using an Iphone.
Now am looking out for a case like Ipad casing, called AAAs, they dun carry such case only those slip in type. Want to order via ebay but again never order B4 thus need to explore...
Jiele2008
no $299 :(
Aiyo...Sporean profile, must fast leg fast hand, on the day of promotion on last Friday,almost all sold out in all branch.
I need to pay in advance to get the booking and I collected my set on Sat....:D
Jiele2008
Universal casing for 7' tablet
Previously bought this cheapo universal case for $5/-.....it comes handy for this new toy..l:s8:
Jiele2008
Tab P1000 silicon for my mediapad
92-95% fitting, depend on each assessment. As seen from pictures 3 and 4, need to cut it in order to expose and get access to the ports...:D
Damage :$8.50/-
