Galaxy S3-Accessories for Humans!
ragnarok95
Senior Moderator
Senior Moderator
The samsung slim transparent casing is by far the BEST casing i had used on my S3. With this, i hardly look at any other casing now. At a price of S$38 for 2 casing, it's quite worth it. You can get cheaper in the forum or thru bros here who decide to sell it off.
Why i say it is good?
1) Transparent. Your phone look as if there is no casing fixed. But there is!
2) Lanyard holes. Good for people to hang all sort of nonsense here.
3) Slim. Doesn't make your phone fatter.
4) All round protection. Yes. Top, bottom, sides are ALL protected.
5) Tough and light weight and easy to remove and fix.
6) Pattern back for better grip.
With the above few points, why should i look at other casing?? Rock/Casemate, really regret buying those cos this samsung design casing is so much worth it, so much better.
No regrets and totally 1000% worth it.
Gixxer1000
any picture of this case?
maximoz
ragnarok95 is spot on. My sentiments exactly ;)
hahaibm
SGP Ultra Nano Clear & Optics now also available in Funan IT Mall: Digivue 2nd floor, Farle 2nd Floor, South Asia 3rd Floor and AAAs 4th Floor, they provide free installation.
helplesssoul
One qns, no offence, will it turn yellowish over times?
hishouken
This is true. I have used a few 3rd-party slim cases (Nillkin & Rock) and flip cases (Rock) and when I hold my friend's original S3 transparent slim case I was overwhelmed... It fits my requirements exactly! That's it, I'm going to hunt down one!
kEvinErd
Not sure....cos only using for a short while only... :crazy:
If it turns yellow over time then it's really wasted.. Anyone has any pictures of the pebble blue decked in the official slim case both white and blue color? Can't seem to find any..
I'm using the Rock quicksand case now and I must say I extremely love the slim factor, look and feel. But I'm always open to more casings for my phone! :)
ragnarok95
Senior Moderator
Senior Moderator
White stuff will turn yellow over time. No choice also. If u love the slim factor, then u will like this case...
Jumpman23
Where to buy it?
icestorm
anyone knows what cables should i get?
like some cable to allow usb connection etc? And where to get them?
Any portable chargers recommendation which outputs more than 1A?
continuum
It's called OTG (On-The-Go) cable or OTG adapter. You can get it from Sim Lim Square. It should cost <= $5. But bring something (e.g. a thumbdrive or a mouse) to test because not all cables work (even though they fit).
continuum
Btw, does anyone know where to get Galaxy S3 MHL cable at a cheaper price? I went to SLS first floor and they were selling it for $58 and it looks like an S2 cable that has an S3 sticker pasted on the box:
The same cable was selling for RM109 in KL. The following YouTube video suggests that the code is EPL-3FHUBEGSTD:
IcYFl4mEz
such cable no need buy original one , buy those unbranded etc for below $10
