- Mar 9, 2004
The samsung slim transparent casing is by far the BEST casing i had used on my S3. With this, i hardly look at any other casing now. At a price of S$38 for 2 casing, it's quite worth it. You can get cheaper in the forum or thru bros here who decide to sell it off.
Why i say it is good?
1) Transparent. Your phone look as if there is no casing fixed. But there is!
2) Lanyard holes. Good for people to hang all sort of nonsense here.
3) Slim. Doesn't make your phone fatter.
4) All round protection. Yes. Top, bottom, sides are ALL protected.
5) Tough and light weight and easy to remove and fix.
6) Pattern back for better grip.
With the above few points, why should i look at other casing?? Rock/Casemate, really regret buying those cos this samsung design casing is so much worth it, so much better.
No regrets and totally 1000% worth it.
