WonderGirl
- Mar 17, 2003
Now I clicked MAPS it said login failed. How to resolve this?
Login so that you can save and latitude your maps. Does your voice works?
Alternative installation method:
Note:
For those who get the “Login Failed” message Pull down the status bar and press all three triangles and give permission then closing maps.
If you don’t get the three warning triangles
1. Install original maps from market.
2. Sign in and join latititude
3. Back up maps in titanium, app and data.
4. Wipe date and uninstall maps
5. Install maps6.9.0-mod-signed.apk. DO NOT RUN, reboot right after installing.
6. After reboot, go to titanium and restore DATA only.
yea and unchecking auto-update on the marked.
Okay... mine is done after using the instructions above. Can log in, with voice navigation and all that. Cheers!
what is all 3 triangle ?
mine only search for gps when in navigation , when in map it lock str8 away... headach sia !To solve that issue now go play and download GPS Status. Then go menu under tools click manage a-GPS state. Press reset and leave your phone open space area for 5 to 10 mins to gather data.
Then go back launch navigation and should resolved. I used that just now to drive very nice with voice interaction now. Cheers.
That 1 is permission to give for the maps to work. If no triangle appear use that method to install. Now mine all can log in. The hacked Google maps very shoick, thanks for intro.
Just those regular permission triangle. I already clear away mine and I got 1 triangle only do I use the other install method above. Just download GPS status and your navigation searching issues would be resolved.
Note:
Can anybody help me to verify when u plug in the charger to charge the s3 when the screen is off the phone will vibrate and wake up the screen irregardless of the mode of profile?
Yes................ but it will screen off after a while
and in case if you are also wondering..... when the phone is fully charged, the screen will turn on for a few seconds and goes off.
"Buy" indeed... pm me for it la...
dun give me points pls...
