Samsung Galaxy S3 - It's Finally here!
WonderGirl
Alternative installation method:
Note:
For those who get the “Login Failed” message Pull down the status bar and press all three triangles and give permission then closing maps.
If you don’t get the three warning triangles
1. Install original maps from market.
2. Sign in and join latititude
3. Back up maps in titanium, app and data.
4. Wipe date and uninstall maps
5. Install maps6.9.0-mod-signed.apk. DO NOT RUN, reboot right after installing.
6. After reboot, go to titanium and restore DATA only.
yea and unchecking auto-update on the marked.
Okay... mine is done after using the instructions above. Can log in, with voice navigation and all that. Cheers!
IcYFl4mEz
Note:
what is all 3 triangle ?
WonderGirl
To solve that issue now go play and download GPS Status. Then go menu under tools click manage a-GPS state. Press reset and leave your phone open space area for 5 to 10 mins to gather data.
Then go back launch navigation and should resolved. I used that just now to drive very nice with voice interaction now. Cheers.
IcYFl4mEz
mine only search for gps when in navigation , when in map it lock str8 away... headach sia !
That 1 is permission to give for the maps to work. If no triangle appear use that method to install. Now mine all can log in. The hacked Google maps very shoick, thanks for intro.
can gpgt the icon i want see? i cant find the triangle , but just now when i pulll down the status bar i heard "connection lost" .
WonderGirl
Just those regular permission triangle. I already clear away mine and I got 1 triangle only do I use the other install method above. Just download GPS status and your navigation searching issues would be resolved.
IcYFl4mEz
I downloaded liao and i resetted . but i ahven go back navigation cos im inhouse ... wait till im outside :D
fabianlau
Note:
Thank it worked ..
Free_MaN
Can anybody help me to verify when u plug in the charger to charge the s3 when the screen is off the phone will vibrate and wake up the screen irregardless of the mode of profile?
kennyg1969
Yes................ but it will screen off after a while
and in case if you are also wondering..... when the phone is fully charged, the screen will turn on for a few seconds and goes off.
Free_MaN
Strangely mine doesn't vibrate. Time for service center again. Just went last week to repair the screen. Zzzz.
Streetwise
Can ask:
1. Should not update from google play store right since this is modified version?
2. Is the offline save map avail in this modified version??
TIA
