aucheukyan
FREEDOM IS BACK!!!!!!!!!!!!!
New full Burst Mode is awesome:s12::s12::s12:
http://www.youtube.com/watch?v=2DLY-xw4nKQ
skip to 17:20 to watch it:D
Couple more new scenes too! I just realized they removed the flashback episodes. i wonder how much is the bluray for this...
now im just waiting for someone to make this a wallpaper:
wah the railgun no more yellow beam liao:eek: and the head vulcans fires too, wonder what it will hit:s8:..... but the shoulder vulcans still underutilised
AikiBoy
just finished this
more pics can b found here and can b found here
i always have this idea of making a full white titan age, black belt, red hand doing a "Shin shoryuken" :s13:
im not trolling lol
that my idea age titan just no time to do a "street fight ryu" color age1.
very sian to do my rg freedom after breaking the mouth mask
sliver0503
im not trolling lol
but u r only left w e head of freedom for completion. do try cement.
will be looking forward to seeing your streetfighter titus!
tanyieern
hi,
Im going to try hand painting soon... Is there anything i should take note of?
I have some unanswered questions...
Q1. Mix ratio: how much water/thinner to mix with paint for tamiya acrylic?
Q2. Thinner: tamiya thinner or rubbing alcohol or industrial thinner?
Q3. Brush: any particular size/type that is suitable for 1/144 kits?
thanks in advance!
p.s. does thinner weakens RG frame?
ongkh2000
Just finished this:D what do You guys think?
imho ur kits have nice poses. they are snapfitted i presume?
can start to clear nubs/seamlines, i can still see them. and since you're doing that maybe u can go ahead and do some simple painting? just my sgd0.02
destin00
I scared at painting...scared later ruined it....got any tips on handbrush?
destin00
hi,
thanks in advance!
I thought Acrylic is water base? And thinner... yeah it melts PLASTIC!
tanyieern
Uh... Then y some ppl use thinner to remove panel line?
Ill stick to water then.
How u guys prime when hand painting? Spray can primers or hand paint primer?
Cleaver
hi,
thanks in advance!
I only use water for acrylic paints, ratio wise, I only mix a portion of what I pour out with 2 or 3 drops of water at the side, just need to dilute the paint a bit.
Make sure its not too thick will do. Need to paint minimum twice for me
Want to use thinner, than use tamiya acrylic thinner, industrial thinner is use to wash the brush and plates where u mix ur paint.
Hand paint I don't prime, as I don't change the color.
Brush size, up to you, bigger parts bigger size
tanyieern
That answers everything. Thanks alot!
ongkh2000
this question has been asked over and over again on this forum..
you can either google or try the local plastic modelling forums :
plamo.outthere.info/forum
or,
sggunplasociety.com
other wise, u can head down to local hobby stores to ask them for any tips/advices.
