The Huawei MediaPad, 3G 7" tablet, now in Singapore!
shokbakgoc
Hi
I visited COMEX last week and realized Huawei did not promote the 7' Mediapad 3G tablet but just the Mediapad FHD and the Mediapad Lite
I checked with Challenger as well but it looks like they are not selling as well. Do you know where I can go to purchase this unit? I like this tablet because it is giving 1280 by 800 screen resolution. And what is the expected price at the moment?
And I must say the FHD looks GOOD but price is a little steep.
Regards
Bob
Did you really go to COMEX or did you just look at the online brochures only?Huawei was promoting the original 7" mediapad. The sales person kept telling me the mediapad lite was on pre-order only and the original mediapad could be purchased immdiately. I tested both display sets and decided to wait and see how first.
bobaccord
I did visit COMEX and Huawei booth and the sales rep keeps pushing the Mediapad lite to me. Admittedly, I didnt see the original Mediapad on display. Perhaps I miss it. Do you remembers what's the selling price?
Thanks
Bob
dennisleu
I use an app to save battery: juicedefender. it works great since it will disable 3g connection when it is not being used. It only turn on every 10 minutes (if i am not wrong) for apps to fetch data in idle mode. Well, i did not take note on how much it improves the battery, but it is quite good app.
actually the HMP already comes with a power saving mode switch kept in the Settings. it does almost the same thing as JD.
dennisleu
my hard back shield.
colonelsoh
sorry to bump thread but the comex deal $278 for mediapad 7 lite still can buy frm outside?
i want to get one.. this one is there any super laggy issue like Acer A100? I rmb my old acer the touch screen not so good always will misclick
anyone call fill me up with more info?
chuah23
If I consider selling my mediapad 6 months old, full package with box, customise screen protector since day 1 plus brown flip case( like iPad case), anyone interested? Please pm me with the bid, thanks..
damienloh
How much is a new set?
eatcarrotcake
Btw I have this experience. Whenever I put it to sleep the energy sapping is very apparent. I have to shut it down. Is there any settings ?
fwl18
Hihi all have you ever experienced the Mediapad shutting down after with a Sim card in the Sim card slot? It'll reboot and shut up upon showing the home screen. This only occur when I have a sim card in -_-
dennisleu
where did you buy this? anyshop in Singapore or order online?
i bought it from ebay. it's a "Nillkin Hard Cover Case". around usd16-18.
it's almost next to impossible to buy any accessories for our HMP locally. if you are getting from sg shops, you have to either cut-to-size (e.g. screen protector) or customize here and there to fit (e.g some samsung galaxy tab cases).
dennisleu
never. my HMP is always fitted with a M1 data sim.
eatcarrotcake
My mediapad is ok with sim card as well. No issue at all. Can make phone call etc
Btw anyone experience battery drain while in sleep mode ? Or is it due to me activating fast boot? The fast boot is really fast. Sometimes faster than some app opening!
dennisleu
my battery drain is average which is normal for 3G connection. that's why my set is always in power save mode (3G will be auto cut off after screen off for >30mins). on average, i only use around 1 hr++ a day and it can last me 4-5days per single charge.
as for the fast boot thing, i can't see the difference. even when it is activated, my set still takes a while to boot. anyway, i rarely fully shutdown the tablet so the slow boot doesn't bother me. mostly just screen off.
are you using wifi? may be you try to manually switch off the wifi first, before letting your set go into sleep mode. because if the wifi is running in sleep mode, then it will be consistently polling for wireless connection. this put a toll on the battery greatly.
fwl18
thaNks all,my sim card problem is fixed after reflashing! but another problem now!!argh!! my mediapad shuts down at 60%...damn sian...did battery calibration also no use
