Huawei Honor U8860 non camera Users come in
Nakedtoes
Mine is after update the 2nd one then stuck at ^ok^ didn't reboot. So I reboot myself.. Basically the 2nd one add in some wallpaper n huawei stuffs...So far so good some apps can't be use.
Nakedtoes
Overall the default browser Is so much faster. Phone is more responsive. Google Chrome like so slow compare to default browser.
Using gingerbread u can hold on screen n add widgets now cannot so a bit can't get use to it
coldboy
my phone show update fail and now cant boot up
anyone got solution to this?
Force upgrade (Extracted from Huawei Guide)
Step 1. A MICRO SD card of 1GB or more should be available. The MICRO SD card made by Sandisk, Kingstone, or Kingmax is recommended.
Step 2. Format the MICRO SD card (This operation is optional).
Step 3. Copy the Software: main package to a directory named dload.
Step 4. Copy the entire dload folder (with UPDATE.APP in it) to the root directory of the MICRO SD card.
Step 5. Make sure your handset is power off. Insert the MICRO SD card into the handset. Press the VOLUME UP and VOLUME DOWN key, and then press the POWER key to power on the phone and enter the Software Upgrade Mode.
Step 6. When the progress bar stop, the phone will restart, if not , you need to remove the battery manually.
Step 7. Copy the Software: vendor package to a directory named dload. Then Execute Step 4 – Step6 repeatedly. (Product line should skip this step.)
Nakedtoes
Just update Google Chrome now is better but chrome dun support flash right?
DigDub
does background programs close easily like other ics builds?
DigDub
1 package update ok. 2nd package after update it won't auto restart, have to pull battery. 2nd update puts the quick shortcuts back to the pull down bar, and removes the camera app which is present in the 1st package, so recommend that you install the 2nd package.
Vae0910
How do I update to ics? Dl the zip file thru desktop an connect my phone to it or dl the zip file directly to the phone?
loster
I try but I got pink screen upon pressing vol and power btn
Nakedtoes
yeah face the same issue as u.... after 2nd package just stuck at OK... so pull out batt...
somehow i feel it drain battery quite fast
