Huawei Honor U8860 non camera Users come in
benyap90
anyone have alternate links for the singapore offical ICS non cam download?...
I kept getting error when unzip-ing the file...
Jarvis-
anyone also facing when u press home button... the whole screen need to refresh only show the below menu button then refresh for ard 2 to 3 second then all other icons appear??? ICS also liek this gingerbread also....
Got any nice apps that can help to auto close background program?
This is due to lack of memory.
If your phone is rooted, install automemory killer and set to aggressive profile.
DigDub
the ics update had the same network bug as other countries ics update. after coming out from 2g coverage into 3g, the speed is slow, have to off and on data connection to get back to high speed again. gingerbread didn't have this problem.
after disabling fast dormancy in the build.prop, the problem seems to have disappeared.
nWo
Hi digdub, can you elaborate on this "disabling fast dormancy in the build.prop"?
I also have problems coming out from blind/weak network spots to open coverage, the signal refuses to refresh itself and continue staying low until we do a restart or airplane mode on/off.
DigDub
need to root the phone. then use root explorer to go to system\ and edit the build.prop file. put a # infront of lines with dormancy to make the lines invalid. I'm using m1, m1 I think doesn't do well with fast dormancy.
Jarvis-
even though the honor has better hardware specification compared to the ino one, the ino one seems to be handling ics a lot better compared to the honor in terms of ram management....
AhBui168
so which is better?
Huawei Honor or INO? :s12:
Jarvis-
so which is better?
depends what you are looking for....
with stock GB rom, i would recommend the honor against the ino one if you are able to get your clearance stuff easily (MSD sticker, etc...)
leehuaqing
anyone have alternate links for the singapore offical ICS non cam download?... Keep download fail..
