Hi all,
I see that there are users with issues on the old set-up of white ONT + RG, and black ONT.. I have been using white ONT + RG for 2 years in Bukit Panjang area, and fortunately, the speed and DV have been consistently up all the time.
However, my plan is ending in Dec, and I am aiming for the 200mbps plan @ $49 (hopefully still available when my contract is up). I have a couple of questions.
1) If I decided to keep my current set-up of white ONT + RG, can I get the speeds advertised for 200mbps line? This is a concern as I believe the LAN ports on Huawei RG are only 10/100mbps.
2) If I decided to switch to black ONT (which will mean using DV direct from ONT, and using my own router for home network), how much do I have to pay? (assuming ONT installation waiver) Do I have to pay for the change of ONT? I have looked thru the posts and I could not see any definite answer (or I may have totally missed it).
3) If I decided to use ASUS N66U (@ $209) with the black ONT, will the M1 settings be preset on the device, or do I have to manually set it up (assuming I get the device from M1)? If I have to set up manually, what are the settings (based on page 4 of
[Maylyn's Review] ASUS RT-N66U Dark Knight, I might not even have to set up anything)?
Thanks in advance for you help! (and to AhWei who assisted to upgrade my FW last year!)
