hi bros,
Can give advise on my next rig purchase.
I've set aside about 2k -> gona take out 500 from this to get a new table and monitor..
Any recommendations for monitor? Preferably ~24 inches. I'm not too versed about it but I read the new LG23IPS is pretty good? Would want something ~300 bucks and hopefully low power consumption.. If any bros can recommend a good table would be good too! My current table is sort of fcked up due to the low height of the table -_-
For the main rig setup, I have a couple of things that can be carried over to the main set up. I do not need HDD (combined total of ~4TB space - 2TB Hitachi, 1TB Seagate, 500GB+200GB+300GB here and there other HDDs), SDD (ADATA but not sure what model and series and speed, will check back), DDR3 RAM (have G. Skill 2x4GB + kingston 2x2GB, maybe switching out the kingston 2x2GB for something else?).
So I'd need to get a need CPU+Mobo combo (not sure i7-3770K is overkill? or i5-3570K is sufficient and then go for better board?), GPU, PSU, GOOD CASING with decent ventilation (current setup with Ikonik EN2 but I feel isn't big enough and the vents can't distro the heat off, after installing the Gskill RAM, everything gets damn hot). Please include any cooling required (like fans, whatever!) Maybe get a Sound card along as well.
Currently my set up IS fine but just hand itchy want to up the systems. The HDD section gets really hot (I think I have 5-6 HDDs constantly churning + 1 SSD) and my 2TB drive like going to die again when I use HDD Sentinel to track the health of the HDD. Damn sian and I feel it's because of all the cluster-f of heat in the HDD section, and I don't have a fan to blow things out.
Any bros can give suggestions? TIA!!!
