Huawei Honor U8860 non camera Users come in
blackwire
bro..brandnew 320 whymobile.
no offences ya
For military personnel,
I believe that the non camera huawei need to get from the local 3 telco. Need to show the camera removal receipt and the huawei cert to the S2 dept in order to get clearance and the MSD sticker.
If get the phone from other source, it would most likely be deem unless if your S2 dept dun recognize your phone and you have to get another phone.
Thus, people with local telco cert will state so in their post and ask for a higher price esp since they got the phone at a higher price as well.
DesertStrike
i upgrade from 2.3 to ics, then downgrade to 2.3.6 but unable to root... anyone knows how?
WestGuy
Huawei Singapore
August 7
Dear Users,
Here is the picture sample of the approved version of certification. Also here are some information and tips which will help you endorse your Huawei Non Camera Phones.
1. All existing old cert issue by Huawei will not be affected as long as they have operators' receipt.
2. With the relevant authorites' approval on the new cert, customer do not need to produce operators receipt any more as long as they have the new cert. (Phones from Telcos & Non Telcos)
3. Existing customer that still facing problem going into the camp, can call Huawei Service Hotline or walk-in to Huawei Service to register first and obtain the new cert within 7 - 14 working days.
How to obtain MSD sticker?
1. You will need to show Huawei phone and the new cert to your camp unit security officer to register.
2. Once registered and endorsed by the USO, they will issued MSD sticker for you to paste at the back of the phone.
3. Once that is done, you can go into any camp without any endorsement again.
Corisen
Huawei Honor u8860 Ultra-High Capacity Battery 3600mAH (HB5F1H)
Ultra-High Capacity Battery | Singapore Huawei Honor U8860 (Case & Protector) Specialty Store
If you are looking for a quality battery that provides maximum standby and usage time beyond the stock battery, then the only battery that can fulfill your requirements will be this ultra-high capacity battery.
This battery has a ultra-high capacity of 3600mAH, which is almost double the capacity of the original stock battery that comes with the phone, and provides extended usage of about additional 60% to 90% more than the original battery.
To achieve the ultra-high capacity, the thickness of the battery is about 2 times of the original battery. As such, it also comes with a back cover for the phone to accomodate the extra thickness of the battery.This battery is extremely handy when you go outfield for a couple of days as the phone can last longer without have to recharge.
Specifications:
Model: HB5F1H
Compatible: Huawe Honor u8860 / Glory M886
Capacity: 3600mAh
Cell Type: Rechargeable Lithium-ion
Package include:
1x 3600mAh Ultra-High Capacity Battery
1x Back Cover
Available for purchase online at corisen.wordpress.com or at Magic Cube retail shop at Shaw Towers #01-18 (100 Beach Road).
Opening Hours:
Mon-Sat: 12-8pm
Sun: 12-5pm (closed on PH)
Thanks.
locknlock
hi guys, i have a huawei honour nc , its gets hot after a short while of playing games etc etc any solution to it ?
y3kesprit
guys.. which is the best stock rom you all recommend?
spent hours searching but cant seem to find a good one in terms of memory management and battery life...
I know the singapore version of ics is not that good.. so which is a better alternative? do share the link! thanks
Jarvis-
the default sg GB rom
shadowandy
cannot :( . follow every steps, but stuck on the root.me.cmd , after that nothing prompt out .
Make sure the adb drivers are installed and the phone is correctly recognised by the adb drivers in device manager
shadowandy
I did. Even there's prompt out saying the drivers is installed
You should see either "ADB interface" or "Android USB Device" listed in Device Manager if you enable debugging.If you don't see either one, your device is not correctly recognised.
3dwintan
I faced the same problem and I have checked and it does indicate ADB interface....after i exe the root.me...the cmd came up and it juz say daemon not started..and daemon started at port XXXXX(cannot remember the number).....after that we supposed to get a new app superuser right? dun have...used the software to chk if the phone is rooted...it say no....
what seems to be the problem?
shadowandy
You can actually open the runme with notepad and try to manually run the commands inside. I suspect it is waiting for your device. I got this before and got it fixed when I got the adb properly installed. I uninstalled the existing huawei devices and replugged the device and all the adb interfaces are recognised. Only then the runme works
