[Review] Hugu's Glass Guard vs SGP's Glas.tR
netzach
Hi bros, any advise on how to remove dusts etc from the adhesive side of the SP?? The back sticky side. Many thanks! :)
netzach
hmm the Glas.tR traps quite a bit of dust hor? i can see loads of dust on the sides of the SP. :s22::s22::s22::s22:
jaymessofly
All glass SPs are like that. Tried both Glass Guard and Bodyguardz Pure already. The side tends to collect dust for both.
netzach
Icic. Thanks bro for the info!
Basket, after applying the Glas.tr, one day later I see loads of dust at the side, then I panicked and Kan Cheong lors...so use pen knife to lift up the SP and tried removing the dust. End up the Glas tr chiu and up lorry. Damn sad. :(
Any idea how to remove the accumulated dust at the sides of the SP mahs? Quite an eyesore man. I might be sticking to normal SPs already like that. But Glas SPs damn shiok lahs to be honest.
Btw, you received the spectra wraps already mahs? :)
Have a great week ahead yea! :)
jaymessofly
Haven't receive yet, weekends postman kor kors never work. Hahaha. For me, I just use a micro fiber cloth and try my best to remove all the dust from the sides. Most of the dust gets removed for me.
netzach
I feel like a kuku bird after I chiu-Ed the Glas tr because of dusts at the sides of the sp. lol. Cockanaden siol me!! :(
jaymessofly
Nao using the PS Clear SP rohs...the one that came along with the PS AJ. :(
I don't like PS SPs. A lot holes. I find it damn ugly. ): I only got for glass SPs or skins.
Can give Bodyguardz a try bro. If you want. I find that it's not bad.
netzach
Buy from FlushX and ask him to install for you loh... ;)
i really do like the feel & look of the glass SP man. it's a real pity that dust accumulates on the sides of the SP. how do you get rid of the dust accumulated on the sides of the glass SP huhs bro dip?? :o:o:o
LLST use the PS SPs for the time being first. :(:(
But in all honesty, the PS SP is not too bad lol. Clear & fingerprint smudges are quite minimal. lol :s13::s13:
deep3lue
My Glas.tR didn't collect dusts at the sides leh. :s11:
netzach
Serious bohs? The very day after I applied, the sides full sheet load of dusts there man. TMD. how you applied one huhs? Pro is pro man lol
deep3lue
You need to make sure your fingertips are dusts free when you apply the glass SP with your fingers loh.
If you can, use scotch tapes instead of your fingers to align the glass SP onto the phone..
netzach
Damn high level sia you bro. Respect dip dip!!!
:D
jaymessofly
Completely no dust at all?
Mine still collects dust ley. But is on the edge. So it's removable if I just wipe it away. No dust at all during application, so got no dust between the sp.
