AhWise
- May 14, 2008
Hello~
Will like to check with you guys about the downtime (scheduled maintenance) for M1.
Shows here that its down every Tuesday from 1am - 6am?
Does that mean you wouldn't be getting connectivity at all? So what if you're torrenting? Kaboom?![]()
just refer to M1 for more accurate maintenance time.
do note the schedule does not always affect the entire fibre broadband user and usually their affect a certain zone. If you are staying at Bedok, then your zone (CO) is under BD CO etc..
amd if u are torrenting when the maintenance kicks in, the most u lost the connectivity to seed/leech.
