AhWise
- May 14, 2008
- for DV, i saw from prev posts that it takes abt 7 days to transfer. i am assuming that this is only is you are coming in from another operator. my DV service is barely disrupted (except on the nite the vlan tagging was removed, but next morning it is fine), so if u are a recontract customer, u may not need to worry about this. maybe AhWise can clarify on this?
*Special note*
When u call 1627, always tell them to indicate in ur case log on what u requested (dates of appts, date to deactivate vlan, waivers, stuff like that) cuz i think there is a history for them to refer. my mistake was i assumed they will take note, but after some calls in and realized there are no traces of my prev calls, i proactively told them to note what i said down. it seems to help.
juz my 2cents worth.. M1 by far have the best fibre service (comparing to my other friend with other ops fibre plans), but maybe customer service wise, can still improve..
7 days is for number porting from ISP. Recontract customer should not have much downtime, like what you mention, once vlan tagging is removed, it should be usable directly from the black ont after restart. problem is when its removed and when u restart it.
as mention, it be important to call 1627 to clarify all the issues before going down. if you are a m1 mobile subscriber, usually have a call log to refer to. use your mobile line to call in =)
