Itronics ITB100HD
XuiteShop
Just got mine installed yesterday. Installed the PC software and turned Parking mode off, but today I checked the SD card and still found recording every minute while parking for more than 6 hours in the same place. Any advise on why this is so?
Thanks!
That is a very big mistake to turn off parking mode. Turning parking mode off in the software simply Means to record continuously without motion detection. That explains your Every min recording.
Eviltrap
Quality still good, i seen the video before
I think theres one person here install for front and rear
Forget his nick liao :D
Thanks for the info!
Then I think I will get a rear one when I have the budget. :D
My current F500HD really cannot make it. :(
ngsoonle
Oh mine, thanks for the explanation!
linzw00
a pic of the night rear view..
eurofunk
When stationery can see, moving time abit difficult...even ITB for the front sometimes at night can't capture clearly when moving esp if the car just zoom pass u
gaolow
Anyone using the new Power magic pro (the one that come with the on/off switch) for the ITB-100HD?
endlssorrow
ITB-100HD costs $350 right? any special discount ? btw can it be fix on behind rear?
ckyc
Quick question. when you review the video - what does video E P N means respectively?
ZhuTou!
E is something like a sudden image/recording/impact
Something doesnt look normal
I also duno how to explain coz when theres no impact, "E" will come out too
Juz leave it :D
P is parking mode
N is normal recording like when u open door, started to drive etc
XuiteShop
Juz leave it :D
P is parking mode
To add on,
E basically Means event, if you place the sensitivity of the shock sensing to maximum, it will be triggered even by the closing of the car door or when the car is travelling at high speed which causes vibration of the car or going on uneven roads like hump etc. So recommended settings for shock sensing during driving is least.
ckyc
Many thanks Zhutou and xuite. i had my 100 for 1 week plus and yday i took down to review. its functioning well. lol my wife was impressed when she saw that my video actually has google map + speedometer. only downside is the SD card is too small so only contains 1 day video. maybe will buy a bigger sd card for it next time.
cheers
