[GFX] MSI Twin Frozr Club
dawntime
hoot dac.. i suddenly feel pcie slots very precious:s13:
DAC jin ex right? I don't think I need second 660 for my needs...
M10 $109 and STX $240+ like doesn't make sense leh..
Heard people mentioning that spending more on speakers than sound card is the way to go :s11:
KeYoKe
Ur dac or soundcard shld cost half of ur speaker budget. If u wanna hoot stx, u shld get a m50w instead. If u wanna get m10, get a xonar dx or dgx will be better
terence52
+1. M10 + onboard should be good enough..
DAC got cheap and expensive one as well.
And tbh, if you want to get a soundcard, A Xonar DGX should be enough for the M10.
KeYoKe
+1 for this. Unless u r using some higher end systems den is recommended for u to buy a better dac.
dawntime
WAd wind blow u here? :s13:
His 680 thor :s12:
Satisfied with my new m10. Change target from STX to DG/DGX :o
What is a DAC used for and how is it different from dedicated sound cards?
Only know DAC is digital to analog converter... nothing else liao :s11::s11:
KeYoKe
His 680 thor :s12:
Imo, cheap dacs like wad terence is using e.g. audinst mx2 can hear more details den sound card. However different dac got different sound signature depending on the dac chip aka op amp it uses. Some dac allow user to swap op amp.
royston87
needs then tri sli 680? 2:1 average ratio
come here SSRR lo this sat build rig for friend
why so mafan~ onboard toslink out to Focal xs 2.1:s12: or the Z906
royston87
i feel.. for games.. soundcard ba.. so called surround:s13:
dac is more for overall. and moreover all our ears different :(
clon22
Suspended
hmm..not really..perhaps i got a fan blowing directly at me. the cpu is placed on the table beside a closed window but the air vents (where i can install 2x 120mm fan) is facing the monitor side. and today the weather is gloomy so environment temp is still alrite.
This is in an open set up.
In casing +10 for a more accurate estimate.
KeYoKe
Icic. Wad gpu is he getting?
Focal xs 2.1? I find it sounds sucky tbh.
And pls z906? Sounds like ****. Boomy bass with no details. Coloured highs and mids.
The only focal i like is focal bird 2.1, the with an amp, which costs like 1.5k sgd -.-
KeYoKe
Dac more for music listening. As dac dun support 5.1 or 7.1. Im too tired to game even when im hm frm work. Lie on bed with music, kiao ka, si bei song lol
zjlim86
WEst where u stay? I got spare. U wan meet me for it? Im located at cck area
Hmm..let me try to get it before i ask one from u..hehe..will be going down to corbell probably fri...so still got some time to source for one first
KeYoKe
NO problem. Pm ur contact number so.i can contact u if u need one. My hse got quite a number, so can give u :) u stay west side i can meet u on my way home frm work since i work near boon lay
zjlim86
Np, good enough bro.
Thanks! :D
:s13:
Adviser by default.:D
That's really weird.
Any issues with games etc? Like hang or auto-close off and revert back to windows etc?
I'll get a card and test it later.
Update later in the day.
I'll prolly be doing testing for the whole of the afternoon.
Lots of stuff haven't touch.
You can use the anti-static bags from mobos is fine too.
Otherwise use the sponge from the mobo box and wrap it around the card
and tape it up, should be fine too. :)
Playing game is still ok..except when i play D3, i cant set it to max setting as I will experience some lag. my mobo dun have any sponge and bag, all of it kana eaten by the shop...damn it..haa
and also using dawntime's method, indeed hot air is gushing out from the gpu when running furmark. did not even have to wait 2 min.
KeYoKe
If no hot air gush out frm e gpu den the more u shld worry :s13: once u start furmark ur gpu chip will start working, so its normal la. But ur temp is on e very high side or even more then the threshold we recommend ppl. U wanna take a screenshot and post it here? Maybe u see the wrong temp? No offense but may happen
zjlim86
wah!! work at boon lay even better...I live around boon lay area. can you pm me ur contact instead? I will contact you if i need a bag from u?
clon22
Suspended
helping friend build rig. should i do twin forz?
Post your requirements?
Maybe can get TFC bros to suggest for you too.
If ur r not gonna OC.
3470 + B75A+G43 Gaming
G.skill RipJawz X 1600 4GBx2(or 8GBx2)
Labour day promo MSI GTX660TwinFrozr
SeaSonic M12II-620W
Sharkoon T28 Red
Just thinking... :)
