dawntime
- Feb 4, 2011
Shld be ban leong. See ur mobo box sticker
Will give it a check, thanks again
*Eyeing on STX for my new swan m10*
*Eyeing on STX for my new swan m10*![]()
hoot dac.. i suddenly feel pcie slots very precious![]()
DAC jin ex right? I don't think I need second 660 for my needs...
M10 $109 and STX $240+ like doesn't make sense leh..
Heard people mentioning that spending more on speakers than sound card is the way to go![]()
+1. M10 + onboard should be good enough..
DAC got cheap and expensive one as well.
And tbh, if you want to get a soundcard, A Xonar DGX should be enough for the M10.
His 680 thorWAd wind blow u here?![]()
+1 for this. Unless u r using some higher end systems den is recommended for u to buy a better dac.
His 680 thor
Satisfied with my new m10. Change target from STX to DG/DGX
What is a DAC used for and how is it different from dedicated sound cards?
Only know DAC is digital to analog converter... nothing else liao![]()
Ur dac or soundcard shld cost half of ur speaker budget. If u wanna hoot stx, u shld get a m50w instead. If u wanna get m10, get a xonar dx or dgx will be better
or the Z906Imo, cheap dacs like wad terence is using e.g. audinst mx2 can hear more details den sound card. However different dac got different sound signature depending on the dac chip aka op amp it uses. Some dac allow user to swap op amp.
This is in an open set up.hmm..not really..perhaps i got a fan blowing directly at me. the cpu is placed on the table beside a closed window but the air vents (where i can install 2x 120mm fan) is facing the monitor side. and today the weather is gloomy so environment temp is still alrite.
needs then tri sli 680? 2:1 average ratio
come here SSRR lo this sat build rig for friend
why so mafan~ onboard toslink out to Focal xs 2.1or the Z906
i feel.. for games.. soundcard ba.. so called surround
dac is more for overall. and moreover all our ears different![]()
WEst where u stay? I got spare. U wan meet me for it? Im located at cck area
Hmm..let me try to get it before i ask one from u..hehe..will be going down to corbell probably fri...so still got some time to source for one first
Np, good enough bro.
Thanks!
Adviser by default.
That's really weird.
Any issues with games etc? Like hang or auto-close off and revert back to windows etc?
I'll get a card and test it later.
Update later in the day.
I'll prolly be doing testing for the whole of the afternoon.
Lots of stuff haven't touch.
You can use the anti-static bags from mobos is fine too.
Otherwise use the sponge from the mobo box and wrap it around the card
and tape it up, should be fine too.![]()
Playing game is still ok..except when i play D3, i cant set it to max setting as I will experience some lag. my mobo dun have any sponge and bag, all of it kana eaten by the shop...damn it..haa
and also using dawntime's method, indeed hot air is gushing out from the gpu when running furmark. did not even have to wait 2 min.
once u start furmark ur gpu chip will start working, so its normal la. But ur temp is on e very high side or even more then the threshold we recommend ppl. U wanna take a screenshot and post it here? Maybe u see the wrong temp? No offense but may happenNO problem. Pm ur contact number so.i can contact u if u need one. My hse got quite a number, so can give uu stay west side i can meet u on my way home frm work since i work near boon lay
Post your requirements?helping friend build rig. should i do twin forz?
