[Maylyn's Review ~ Networking] ASUS WL-330NUL
maylyn
Road warriors should rejoice with the new ASUS WL-330NUL pocket size router from ASUS. ASUS doesn't just make routers for home/SOHO users but they know frequent travelers need something small and convenient to bring along to help them stay connected at anytime of the day.
Stay connected wherever you go!
The ASUS WL-330NUL is the world’s smallest pocket router at only 17.5g in weight and 6.5cm long. Whenever you’re traveling or simply at a cafe, getting online becomes so easy with all your devices using this USB stick-sized router. Whether only Wi-Fi or wired LAN are available, it creates your own private network and allows speedy cross-device communication, making it extra-useful in staying connected anywhere.
Some ASUS WL-330NUL package views
Actual ASUS WL-330NUL
maylyn
Overview
What is ASUS so different from the rest of the competitors? so ASUS make something so good that have rise to the occasion? Let's find out
World's smallest pocket router
Hotspot Sharing
USB Ethernet Adapter
Wireless Adapter
Several ways to power the ASUS WL-330NUL
Smartest setup free router / Windows and Mac support
maylyn
Setup
I'm going to present my setup in steps so users are able to follow to configure their ASUS-330NUL
Utility setup is required first before the initial configuration , just follow the instruction prompt on the screen after plugging into any USB 2.0 port
Once you are done, launch your browser pointing to 192.168.1.1, you will be redirected to the ASUS-330NUL administration page
You will need to enter the 8 digit found at the side of the ASUS-330NUL for authentication
Various settings menu are shown on the left panel
First stop, please update the ASUS-330NUL default firmware (3.0.0.20) to the latest (3.0.0.23) there are numerous fixes as shown below, you can download it from
https://www.asus.com/Networking/WL330NUL/#support_Download_30
Firmware updating in progress
maylyn
Wireless Setting
You are able to configure both private and guest wireless settings as deem fit or use the default
Mac Clone
Mac Clone function is very useful if the premises you are in require specific Mac address to connect to the Internet, thus allowing other devices to able to connect to the Internet as well
Guest Management
maylyn
So how's the performance?
Setup
Internet Connection ~ ViewQwest 300Mbps
Connection Type ~ USB Ethernet Wireless mode (Wireless Card mode)
Frequency ~ 2.4GHz N mode (AES)
Distance ~ Optimal (2m)
SpeedTest-SingTel
SpeedTest-SGIX
SpeedTest-ViewQwest
BBQ-Amazon Singapore
Not too shabby results at all, taking into consideration of it's size, it's still capable to deliver 30+Mbps download and 20+Mbps upload
Nevertheless it's the various mode of operation that one might want to take a serious look, it's size, flexibility and ease of use in different scenarios is something none other makers have yet to come out with
Job well done ASUS ^^ for scoring the world first pocket router in this form factor
maylyn
Before any jealous critics comment that it's only capable of delivering so "low" speed, please back your comments with proof with something similar in size :s13:
Bear in mind, the above test it's conducted in 2.4GHz wireless
Want top speed? it's can be done as well, by using the Ethernet Adapter mode but it will ease to be a router/wireless mode (not able to perform wireless and router function)
SpeedTest-SGIX
SpeedTest-SingTel
SpeedTest-ViewQwest
Good enough? hehe nothing strange with these results as it's capping the 100Mbps LAN Port with overheard
maylyn
Reserved for any new updates
ASUS-WL330NUL with supplied power adapter (it's 3 pin version)
maylyn
I saw the hardware specs...it is Realtek :s39:
Anything wrong with Realtek? ;) :s13: cheaper chipset manufacturing, people wants to complain, premium chipset and better manufacturing, people wants to say it's too expensive :s13:
You will get to see another ASUS networking product using Realtek coming soon :s13:
Inix
If anything, I'll buy it for the fact that it shares Wireless from Wireless. That's something which most such small devices are not able to do yet.
maylyn
That's right ;) it's something which ASUS has accomplished first when most of other maker "small" devices are not able or yet to do it :s13:
ralfale
I bought this on day 1 of launch monday.
Its working great for my overseas trip. Its an excellent product at an amazing size.
Im loving this.
maylyn
Im loving this.
Nice :p it's a must buy for road warriors :D this shows ASUS is listening what people wants and has delivered and newer innovation to deliver better products will never ends ;)
zetavinz
Hi. I'm recommending this to my friend who is going overseas. Can the router function without the need of configuration via Windows/Mac?
My friend will only be bringing android devices overseas, so is the initial configuration only for First-time install. Then you can use it overseas straight?
maylyn
Initial configuration/setup is required.
For Windows, installation of the utility/drivers are needed, the utility/drivers are in the pocket router.
For Mac, installation is not required.
excezz
I have tplink but there isnt a hotspot sharing mode which makes it impractical for me to bring overseas. I think asus is still best because of that feature.
runtime
Gd day...
Some issues encountered... maybe is just me...
1) May I know what is the initial configuration for? I tried to run setup.exe and is seems to just install the application for the PC to get connected to wireless router and to do the 330NUL configuration. When I access 192.168.1.1, it seems that the configuration can be done there too.
2) We are not able to choose the mode manually? The 330NUL will choose itself? What if I want to use the PC USB power and to use different mode?
I only managed to try out as wireless adapter mode. Initially I am not able to see the "Mode" tab in the installed app on my PC. I also have trouble connecting to my wireless router even after adding the profile manually. It keeps prompting me that the information is not the same as my wireless router. Even after adding the prompt, the profile disappear from the profile page of the installed app. Anyway, after a few rounds of re-install and reboot, I managed to connect to my wireless router.
3) I saw a few wireless names in the neigbourhood in the installed app after scanning, but after clicking on the "refresh" button, all disappear and I have to unplug 330NUL, re-plug it in and the wireless names will then appear again.
Still trying out...
Hope to have some advices from you.
Thank you.
