Xperia Tablet Z, Sony's next Android tablet?
mikengtw
Yap I saw it at Junction 8 wa the weight and the size
just nice to hold ... tonight I cannot sleep already .
Tomorrow must q up to buy ... dam good I love it. Can't
wait to bring home to play with it... :)
lorettatay
good place to q? think i will get the wifi 32gb instead...
sG_KYo
Not bad this tablet got rated best tablet at techradar
aiyah ... all the rating all a bit kelong one lah ...
For example ... anything not samsung to me if i write ... also RATED Better than SAmsung.
:p
maumu
There's a dummy set at Junction 8. I wouldn't worry about the thick bezel if I were you. Having used and owning one, the word "Heavy" will be the last thing on your mind.
would 'dummy' set means it's not the same weight as the actual? it's just a 'shell' right? also cannot see the actual screen resolution and stuff...
best_ctzn
Tomorrow please do not cry when you finally get your xtz! Please be strong.
Do get someone along if you need a hug or some support. Don't faint and be headline material! Very embarrassing you know?!
Audiology93
Good luck to everyone who are getting it tml :D hope there's display set over at jurong point as I've never seen an actual one b4
metalB
That's true, i feel the weight is either close enough or slightly heavier. I guess you can have at least have a look at how thin it is. I can definitely hold the tablet longer with one hand then the ipad 3 for sure.
sG_KYo
it is light ... but not that light ....
it is big ... but not that big ...
it is matt ... and it is not slippery ...
Thus a good combination.
