I was about to rate that MSI Z87 MPower board is the prettiest until I saw this...
Meet the Asus ROG Z87 Maximus VI Formula.
Wow this is really.... very nice
So 4670K can o/c to 4.5Ghz load at 60C then how about 4770K ?
Which is more worth to buy Intel 4670K, Intel 4770K or AMD 6800K ?
Run stable 24hrs, 7days a weeks, ... under hot sg room .
Thanks.
Haswell - A Long(er) Life Platform?
Temporary relief from incessant new sockets for a while... ?![]()
... I am worried that while the socket pin count remains the same, there might be something else that breaks compatibility. Like voltage regulator or ddr4 support. Think it happened before in the past....
it's not that we dont trust butlol
Seems nobody can trust Intel on any form of hardware continuity anymore?![]()
Noticed it mentioned 9 series chipset meant for mainstream consumer for the haswell refresh. I am worried that while the socket pin count remains the same, there might be something else that breaks compatibility. Like voltage regulator or ddr4 support. Think it happened before in the past....
i wish i can see an encore of the 775 which ran from what?
pen4 to the end of core2?![]()
For Shrek since you asked for it...
Wakao This Uncore leh!
... more uncore settings vs performance, testing Core@4.5_Uncore@4.2GHz
Seems kind of weird findings so far, hope others can try out uncore scaling and post their feedback too. Looks like Core Frequency is really still king and the stock uncore speed is already fast enough to feed the core at 4.5GHz.![]()
Massman says:
15 days ago – If I recall the IDF presentation correctly, the Intel engineers mentioned that "even though the Ring Bus frequency can be adjusted, they have not seen major performance gains in the labs". And then they asked the reviewers and power users to test it themselves![]()
From reading hardware forums, our present local batch of chips seems to be o'cing better than average with all (3 out of 3) of ours hitting at least 4.5GHz easily. Temps will eventually depend on your cooling gear.Do haswell suffer from any heat problem due to cheap thermal grease?Any defect in this 1st batch ,motherboard or chip wise?
It seems that battery boost on portable devices is the only significant aspect of haswell?
