Aztech DSL7000GRV router from Singtel
luv_boa
i am in a dilema whether to sign or to wait. computer too far from terminal.
this modem wireless sucks. change a router i need to get 3 adaptors. everything also must spend extra $ sia
Twinsen
Depending your home wiring, look at home plugs. A pair of 500mbps should yield you speeds of at least 70mbps and upwards? You might not be able to fully utilize the 100 or 150mbps but still better than adsl or cable and the price of adsl/cable vs fiber is not that much diff.
This is probably the cheapest option.
Else if you don't mind a ugly wire casing running in your house, get someone to run a cat 6.
luv_boa
cos i am stuck w singtel home bundle as i got 4 singtel lines.
homeplug uh if i can get at least 70mbps it be good. really is sinktel !!
guyz92
Aztech DSL7000GRV-(S)
I gotten this router after recontacting my fibre service.
This router support Samba File share. IP6 tunnel to singtel 6TO4 and many other features.
The additional feature will require access to Admin Page(http://192.168.1.254/singtel).
I can say that the configuration for this Admin Page unlocks many new feature.
If you need the password you can PM me.
Admin Login Information:
userid: admin
password: H3ll0t3ch
redevils
Between 2wire 5012 and Aztech 7000. Which one would be better for performance?
Thanks.
betadyne
Thanks.
Get Aztech 7000
No joke, its much better. Of course Asus N66 one is betteR (I am using it myself). But for normal usage, the Ztech 7000 one will do fine.
redevils
Get Aztech 7000
Thanks for the info!
As i will be getting a free 7000 for my recon, currently using 5012 for my fibre.
Kvicez
If I'm on the 5012NV, can I request to change to the Aztech model?
Will there be any improvement?
iantao99
How to configure DDNS on DSL7000GRV?
Any bros can advise how to configure DDNS on Singtel DSL7000GRV?
Can't even find tab for it...
Is the Singtel router Aztech DSL7000GRV same as Aztech GR7000?
Can't find DSL7000GRV on Aztech website.
kero89
anybody can shed light on whats the login user id to go into the super admin page?
iantao99
port forwarding
Hi guys,
How to configure portforwarding for this router?
Tried key in data at port forwarding tab but not successful leh.
Thx for advice in advance.
ksteosin
can pm me the advance settings username and password? thanks
dinosaur
Kindly PM me the password too. Thanks!
