-=OFFICIAL=- EDMW PHOTOGRAPHY CLUB - - - Part 12
alanjw55
nikon full frame when use with crop lens, either use in dx mode and fill the whole image circle or will have the dark corners in fx mode right?
Last I read is like that leh
Have 2 modes, came across this when I was sort of reading up on d600 and nikon
robolee
UPS make a delivery today...too bad they dun deliver on sat. resche it on next monday which i am on leave :3
hkingx
I need to get a hard disk
Any good brands to intro? And place to get it??
:o i'd one seagate which i'm using for around 7yrs + and still running fit. other than that i'm using WD too, 3.5" and 2.5" havent let me down yet till now :s13:
EJB
No dark corners, mounting a DX auto activates the sides to darken, only the areas that are captured will be visible clearly through VF. The areas not captured are darkened.
Can't show you a pic as I can't focus thru the VF using my cam.
As for Live-View, it isn't affected, the captured area automatically fill up the LCD.
Wtf, wait they say say only....need black n white on paper wor
My boss won't lie to me, all certifications are like that, pay first then claim. Can claim citerep also, just having to pay upfront, I damn sian.
EJB
Manage to take a shot using my phone. Area outside the red are slightly darkened.
Blue = FX area
Red = DX area
Nikkor AF 10.5 FE on FX.
tecnica
Blue = FX area
Red = DX area
thanks... so it will effectively crop the megapixel count and only use what the lens can capture lor...?
but if you use DX lens but on FX mode, you will see all the dark corners? or it will not work at all?
Mach3.2
I think can..
In Auto mode, the 1.5 crop mode will automatically be activated when you mount a DX lens.
However, you can override this, i.e., select FX mode, even when using your DX lenses. How well this will work (i.e., how much of the full frame will be covered) depends on the particular DX lens you use. Regards. -iwbs
http://www.dpreview.com/forums/post/40998845
Silvialite
That time cesario god use the tokina 11-16 at 16mm on his D700, bo vignetting I think.
EJB
Yes. It will only capture what the DX (red) lens is able to cover.
It will work, just that you will see the darkened areas (blue) around the red.
I used the 10.5 on my D600 for wedding shots, it works. Waiting to sell the 10.5 and get the 16mm FE. This is my only DX glass.
