M1 Fibre Broadband Promotion for PC Show 2013
netsuAi
hi all,
any tips on settings for linksys ea2700 router?
ont > laptop: Can get 200up/180down
ont > linksys > laptop: Can only get 90up/75down
whs9988
Can share the wireless settings to get these speeds on Asus RT-N56U router? Mine is less than that under 300mbps plan.
Thanks alot
Whether 300Mbps or 200Mbps won't help improvement of your wireless speed. Probably your wireless adapter limitation or your laptop hardware limitation. Pls note that iPhone 5 cannot hit 80Mbps whether using 2.4 or 5GHz even u stand next to router as limit of the hardware.
Simonkwq
Who say so ? I hit 81mbps on mine phone
zetavinz
Yes you can try connecting cat6 cables directly to the ont box and do a speed test, I tried mine and got 200 overmbps.
Seeing so many of you guys using Cat 6 cables and having no prob with that makes me wonder why mine is giving prob.
tested the cable on my desktop and sis laptop, still getting 100mbps connection. both using the mobo's Realtek PCIe Gbit NIC
tried connecting a 1m Cat 5e cable directly via ONT and i can get 1Gbps on the laptop.
So the prob must be on the cable. Is a 20m long Cat 6 the prob or was it the very cable itself regardless of length?
ngbc
This could be due to bad crimping or wires damaged inside, get it exchanged with the shop you bought if possible.
Simonkwq
Might be the wiring problem. I'm using 20m cat 5e cable fix the cable myself
zetavinz
not possible since i bought the cable 2 years ago for my 50mbps fibre plan.
so right now my choices are either a new 20m Cat 6 or Cat 5e.
daggerden
hi guys, a quick qn, the m1 guys jsut installed my m1 fibre at home. What I wanna do next is to port over from my mio home digital line to m1 digital home line. I know i need to retain the line then port over. Do i need to convert to anolog line first? Cause i read some thread back, u have to pay $50?!
ngbc
No need.
jeffrey745
Hi guys,may I ask I'm planning to sign up m1 fibre and home voice,may I ask if there are any hidden charges? Like installation charges/activation charges? Thanks!
tishfire
Please refer to first few post.
Current promo before PC Show
For ONT Installation
Weekdays 9am to 5pm -> $58.85
Weekdays after 5pm -> $85.60
Weekends -> $112.35
For Termination/Cancellation of Fibre Service
Change of ONT appointment date -> $32.10
Fibre termination -> $32.10 + Penalty as per contract (within 24mths)
Collection of ONT (Upon termination of Fibre services)
Weekdays 9am to 5pm -> $12.84
Weekdays after 5pm -> $19.26
Weekends/PH -> $25.68
**M1 will collect back the modem from customer premises on the 36-40th day after terminating
Misc Charges
Fixed Voice Activation Fee -> $37.45 (FREE waiver of activation fee upon Fibre plan sign up)
Fixed Voice Termination -> $37.45 (if you took up Fixed Voice service, No charge if terminate together with Fibre Broadband)
Find out more @ 84448944 (SMS & WhatsApp Available)
