Upgrading CPU or GPU
Zakhri32
Hey guys, need your opinions, so I was thinking of upgrading my PC, specs are on the side >
I'll be focusing mainly on the CPU and GPU but I don't know which to upgrade first, most of the games I throw at it runs fine but there are some games that will stutter at times especially in MMOs.
If I'm upgrading my CPU, i'll be going with an i5-3470 and yes I'm not gonna upgrade to Haswell.
For GPU I'm thinking of upgrading to a GTX 760, but will I really see a big performance boost from my GTX 650 Ti Boost? And will my CPU bottleneck the card?
Thanks guys :)
royfrosty
Thanks guys :)
Kinda not sure, as your gtx650ti boost only 1gb.
Personally what my opinion will be the 650TI boost can keep first.
CPU get the i5-3470 ba. How you play games on celeron sia :eek:
Teng Zai
Your CPU really lacking.
1GB VRam I think still can live ba. Besides, 650ti can hardly push past 1gb of vram if you on single 1080p.
i5 IB or Haswell will do.. but then you need get new mobo also lor. Costly. Can almost buy you a 760. But ya no point getting a 760 with celeron, and you play MMO's wor. More CPU intensive I guess.
I don't know why you will stutter though, even my old GPU can play WOW/GW2 no issue leh, just that at mid(wow) and low(gw2) settings. 650ti not say very chor leh, compare with 760 it's not really that far behind.
wuweiz
Go i5 4 cores. Then a few mths later upgrade gfx. At least a 2gb card.
Some games stutter becos of dev problem. Don't worry. But some games need 4 cores to play.
So... i5 3470 bah. Just get a b75 board.
tegeus-Cromis
TS specs say his board is already B75, so not a problem.
Agree with getting CPU first, then GPU upgrade later. Especially if the 9000s come out later this year as rumoured. That's bound to shake up the prices of existing cards.
Zakhri32
Thanks for your guys opinion, I will definitely go with an CPU upgrade now.
wuweiz
Was on mobile.. So cannot see his specs.. :s13:
ahbard
Upgrade your cpu first...Next will suggest a SSD then follow by GPU.
xonix
Yup...agree with above sentiments.
CPU > SSD > GPU ( wait till 9000 series )
xonix
I think his emphasis is on gaming. So it's CPU -> GPU -> SSD instead..
Can also if the MMO he's playing is GPU intensive.
But if the MMO isn't taxing his current GPU, TS can consider the diverting cash to an SSD which will improve the overall system speed.
darkortal
he mentioned stuttering while gaming
SSD is really a want more than a need, for me using SSD don't really feel different except starting up and shutting down pc
royfrosty
Have, in mmo situation is between life or death.
One good example in diablo 3. Going thru a portal if the hdd isnt fast enough to load a map out, your character is actually standing in the open field of monsters. The next thing you know after you have load finish a map you are on the floor with your tombstone.
Teng Zai
Interesting, more things learn today. This process is called rendering right? I know cpu and gpu impact on this but ssd itself also? Haha!
royfrosty
Yeap.. certain things of a game components are stored in the hdd itself. Maps, sounds and probably config files. Some game settings like save files are also stored.
melovelinux
shocking you can survive with dual core. lol i can't survive with my Lappy's crappy AMD "So called" Dual core @ 1.4Ghz, HP Sleekbook, HP installed Windows 8 and it slow as hell.
Upgrade Processor - i5
ragnarok95
Senior Moderator
Senior Moderator
Why i suggest SSD? Because his GTX560ti is still a good card. Get the cpu upgrade and maybe follow by a SSD for overall speed improvement. SSD dun just shut down and start up fast, it make the whole PC more responsive.
Of cos this is just my suggestion. :D
ahbard
My lappy also dual core i5 leh....But since i changed the WD blue 500gb 5400rpm with a SSD...my lappy is on a fly....who say SSD only good for starting and shutting down only?
Opening of apps,web surfing, game loading is like 100x faster and my lappy runs cooler.
